I recently processed a group of jpegs in Pix4Dreact. The output is corrupted. I’ve imported these into mapper and they work fine. Any idea what’s causing this?
This might be related to a GPU incompatibility, could you try disabling GPU acceleration?
Thanks. I tried that and got the same result.
Hi @alanauld23 ,
May I ask if there are oblique images in the datasets? That could be causing the issue.
Rosana (she/her)
Hi Alan,
Thank you for your reply. I reached out to you via a support ticket. I look forward to investigate your dataset further and hopefully to fix this soon!
Rosana (she/her)
