Coordinate system of .las file?
I have uploaded a set of geotagged images to Pix4D mapper cloud. In the online viewer, I can see that the 3D reconstruction of the property is set at the correct GPS location.
I now need to get the digital elevation model of my map. For this I have downloaded the .las file. I can parse it with my own C++ parser or look at it with http://lidarview.com/.
I’m confused about the coordinate system of the data points. They are around 459262.316139 5245125.344528, 565.579197, whereas the GPS coordinates should be around 47.35, 8.46, 500.0 (very roughly).
How do I convert what I am getting from the .las file to LLH?
Some posts on here mention setting the right coordinate system for exporting, however I don’t see any such option in the cloud version of Pix4D mapper.
Thanks!
Hi Nick, This might be relevant to you: https://support.pix4d.com/hc/en-us/articles/215858503-Cloud-general-questions#label8, To get the output in the coordiate system , you want, you will need to define the output coordinate system (select in Pix4D desktop) and the upload from desktop: https://support.pix4d.com/hc/en-us/articles/202558589-How-to-upload-project-files-from-Desktop-to-Cloud
Very helpful, thanks!
Is there a way of seeing in which UTM zone the points are in the .las file?
You can see it in the quality report.
