Hello everyone
Getting the following error message at the beginning of Stage 2 once the clusters (39) have been generated from ~6000 images that were generated as sub projects and then merged.
[Error]: ClusterGenerator: Not enough valid cameras!
[Error]: Generating Clusters Failed!
[Error]: >>>Generating Clusters<<< failed with error (failed to run a step!)!
[Warning]: Group Processing: Failed to generate cluster, skipping cluster
It has begun processing 1/39 and successfully completed the initialization of cameras and points… I am concerned that this skipping of a cluster might leave a large segment of the point cloud missing - if it works. Given the size of the project this is going to take 12+ hours to process and do not have the time to wait to see if there is a gap in the point cloud or if the processing fails completely.
Any suggestions? This is extremely time sensitive and would greatly appreciate some help/advice
