Clear the image-geotags
I wonder if there’s the possibility to clear the image-geotags in P4Dmatic. I know it’s better for the calibration-step to use the geotags, but in this particular case (comparative studies) it ist very important to do the calibration-process based on the image information only.
Thanks for your help!
Julian
Hi Julian,
Can you post this in the Feature Request category? Our developers monitor the requests and the ones with higher votes are more likely to be implemented.
Thanks for the feedback. Indeed, adding a “clear” or “disable” geotags is something we should add.
Note: I moved the post to the “feature request category”, so no need to repost.
Thanks a lot! In the meantime I deleted the geotags before I imported the images. This works too.
