Hi All,
Can someone help me out here? What I am finding in one of my cloud projects. If I re center the map it shoots it off the screen and I have to zoom out to find it again! Is there anyway to rectify this so that when I do re center it actually pulls the map back to the center? Thanks in advance Shane.
What is the ID or name of the project?
Hi. Its called Cromwell Speed Way Full GCPs
Just to make sure, you are using the icon at the bottom left corner. Is it correct? Which output are you using? I have difficulty reproducing the error. If you could upload the screenshots, it will be very helpful to understand the problem.
Warm regards,
