i try the workflow with viDoc and iphone 14pro. In the preview i saw that the LIDAR Pointcloud was cutted at the bottom. Does this effects any kind of results or does this have any effect on the accuracy of the results?
best, D.M.
best, D.M.
What do you mean by cutted? Can you share some screenshots with us?
José
Hi Jose,
thanks for reply. See the attached images. There is less Data from the LIDAR. But the results are finally good. So it looks like this has no effect on the results? Or?
best D.M.
Hi @d.mielke,
Thank you for the screenshot, and I apologize for the long reply time.
How did you create the two screenshots? If the device has LIDAR, it is not possible to turn it off.
Did you acquire the images two times? Did you use two different devices? On the right one, I see that at least one camera is looking a bit toward the ground:
Note: both screenshots show a LIDAR point cloud.
