I try to process multi-spectral data obtained by SEQUOIA and getting the warning:
[Warning]: Warning w9020: GDAL Error <1> latitude or longitude exceeded limits
[Warning]: Warning w9020: GDAL Error \<1\> latitude or longitude exceeded limits
and noticed that even after processing is over, the 3rd step still appears in red colour as if it is not finished.
What I noticed: 3rd step appears red if GeoTIFF (under DMS and Orthomosaic / Orthomosaic) is checked. But if I remove the check, then 3rd step looks green (i.e. completed).
Am I doing processing in a wrong way? Is it possible to complete the processing with Google KML files generated?
Thank you.
Giorgi
ps. here are screenshots
