Calibration Stuck at 27%
Drone image calibrations stuck at 27%. This happened 3 times. They are different images from different flights. Some flights process without a problem some of them do not. And it doesn’t give any errors or notifications about the problem.
HI asli,
Will reply in the private support ticket, let’s update this post when we have more information
I came to this forum looking for a solution to the exact same issue. I calibrated my images, marked 3 GCPs, and selected Calibration again…each time it stalls at 28% and I have to cancel processing. I have also noticed that Reoptimization is greyed out - perhaps this is related? Thank you!
I assume you are referring to PIX4Dmapper? please share the Quality report if any, and the log files.
Best
Hello Jose, I fixed the issue! I had incorrectly marked one of my GCPs and once I remedied that the calibration finished.
