Bring Cloud Data into Desktop for Further Processing
Can you bring a cloud project into the desktop and generate contours and additional outputs and or calculate volumes etc.
Thank you,
Ryan,
Sure, under project menu “Download Project files.”
The option is grayed out so I cannot select that option.
Hello Ryan,
When you use the option Download Project Files you should open a New window so that this option will not be grayed out.
Please note that at that moment is not possible to fully download a project from the cloud. You can download certain outputs, but if you wish to download the full project, then we would recommend to process it locally.
Best Regards,
Exporting the project to desktop it is now fully supported.
