Beta OS X version of Pix4Dmapper 2.2
This post refers to OS X Pix4Dmapper 2.2. Since the release of OS X Pix4Dmapper 3.0_, we have created a new post here, on which you can post your comments and your feedback._
This post will be closed to comments.
We hope version 3.0 will better meet your needs.
How to install the Mac version
Follow these steps to install the Mac version:
  1. Download the Mac beta version from here: https://mapper.pix4d.com/download/mapper/dmg/
  2. Go to Downloads folder and double click Pix4Dmapper_2.2.XX.dmg.
  3. Move the Pix4Dmapper icon to the Applications folder. Pix4Dmapper is now installed.
  4. If you are not the Administrator, authenticate adding the username and password of the Administrator.
  5. Eject “Pix4Dmapper” image.
  6. Launch Pix4Dmapper.
  7. A warning message will appear: “Pix4Dmapper is an application downloaded from the Internet. Are you sure you want to open it?”. Select Open.
  8. Add your username and password. Pix4Dmapper will open.
Known issues :
  • The software cannot automatically prevent the computer from entering sleep mode while processing. For more information on how to manually disable the sleep mode while processing: 208355936.
    You can also download version 2.1.61 from here: https://mapper.pix4d.com/download/pix4d_mapper/2.1.61/mac/
  • The software crashes or the project is not loaded when either right clicking on the p4d file and selecting open with > Pix4Dmapper or when double clicking on the p4d file.
    Workaround: To open the project, start Pix4Dmapper and in the menu select Project > Open Project….
  • It is not possible to create nor process projects with Sequoia images containing Airinov’s calibration target. The software crashes.
    Workaround: no workaround exists for Mac.
FAQ
What about the licenses?
Your existing paid licenses will work just as well on the beta Mac version; it will just count as another installation but you can float easily from one device to another. You can also use the beta Mac version with the free Discovery license.
What are the minimum hardware requirements?
You need Mac OS X 10.11 - El Capitan to run Pix4Dmapper.
At this point, we no longer have the possibility of supporting and testing on Mac OS X 10.10. Upgrading from Mac OS X 10.9 Mavericks and 10.10 Yosemite is free, and all Mac computers that can run these previous versions can also run El Capitan. Upgrading is a fast, simple and safe process done through the Mac App Store and all the files that you have on your computer are preserved.
The beta version has been tested with the following Mac computers:
Pix4Dmapper should run on other Macs from this period, with similar specifications. We recommend the fastest i7 processors and at least 16GB RAM.
We also plan to test the beta version on more Mac computers. Your feedback for compatibility issues with other Mac devices is more than welcome.
Is there any difference between Mac/Windows versions?
The main difference in the Mac version is the lack of Nvidia CUDA, PDF3D and SGM support. We are also working on improving the display for Retina screens. In addition, the Map View does not have a Satellite view as background at the moment.
Is support provided for the beta Mac version?
The Mac version is in beta. Therefore, personal support is not yet provided. However, you are welcome to post your feedback on the Forum to help us improve the beta. You can post your comments, suggestions or issues in this section of the Forum.
Are the Manual and Knowledge Base valid for the beta Mac version?
Apart from the installation of Pix4Dmapper, the lack of GPU processing, the 3D PDF limitation and the lack of SGM, the documentation of Pix4Dmapper is valid for the beta Mac version.
We hope that you will enjoy using the beta Mac version and we are looking forward to receiving your feedback.
I received this message: “Warning w0045: Less than 4GB of available RAM was detected. This might be insufficient for processing larger projects.”
However, my MacBook Pro has 8GB of RAM.
Here’s a copy/paste of my hardware overview:
  Model Name: MacBook Pro
  Model Identifier: MacBookPro5,5
  Processor Name: Intel Core 2 Duo
  Processor Speed: 2.26 GHz
  Number of Processors: 1
  Total Number of Cores: 2
  L2 Cache: 3 MB
  Memory: 8 GB
  Bus Speed: 1.07 GHz
  Boot ROM Version: MBP55.00AC.B03
  SMC Version (system): 1.47f2
Also, Pix4DMapper crashes when I attempted to run the “Point Cloud and Mesh” process.
Below is copy/paste of pop-up:
Process: Pix4Dmapper [1579]
Path: /Applications/Pix4Dmapper.app/Contents/MacOS/Pix4Dmapper
Identifier: Pix4Dmapper
Version: 2.2.25 (2.2.25)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Pix4Dmapper [1579]
User ID: 501
Date/Time: 2016-09-11 14:19:29.694 -0500
OS Version: Mac OS X 10.11.6 (15G1004)
Report Version: 11
Anonymous UUID: A967D4CE-9F12-841F-0A69-49790A425AE9
Sleep/Wake UUID: 9ED6CFD4-602C-4EEF-8785-F628C17B1599
Time Awake Since Boot: 19000 seconds
Time Since Wake: 2300 seconds
System Integrity Protection: enabled
Crashed Thread: 26
Exception Type: EXC_BAD_INSTRUCTION (SIGILL)
Exception Codes: 0x0000000000000001, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Global Trace Buffer (reverse chronological seconds):
624.677363 libextension.dylib 0x00007fff87299533 tearing down extension request for pid 1646
624.677589 libextension.dylib 0x00007fff87299533 tearing down extension request for pid 1584
1965.244499 libextension.dylib 0x00007fff87299533 tearing down extension request for pid 1585
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff8e3fafae semaphore_wait_trap + 10
1 libsystem_platform.dylib 0x00007fff870c6ce8 _os_semaphore_wait + 16
2 libdispatch.dylib 0x00007fff97d81994 _dispatch_barrier_sync_f_slow + 594
3 com.apple.AppKit 0x00007fff84f412ee NSCGSDisableUpdates + 213
4 com.apple.AppKit 0x00007fff84f41124 NSCGSTransactionRunPreCommitActionsForOrder_ + 156
5 com.apple.AppKit 0x00007fff84f41075 NSCGSTransactionRunPreCommitActions_ + 31
6 com.apple.AppKit 0x00007fff84f4104a __39+[_NSCGSTransaction currentTransaction]_block_invoke + 34
7 com.apple.QuartzCore 0x00007fff96998f71 CA::Transaction::run_commit_handlers(CATransactionPhase) + 85
8 com.apple.QuartzCore 0x00007fff969987ce CA::Context::commit_transaction(CA::Transaction*) + 1090
9 com.apple.QuartzCore 0x00007fff969980ec CA::Transaction::commit() + 508
10 com.apple.QuartzCore 0x00007fff969a3977 CA::Transaction::observer_callback(__CFRunLoopObserver*, unsigned long, void*) + 71
11 com.apple.CoreFoundation 0x00007fff8f2df067 __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 23
12 com.apple.CoreFoundation 0x00007fff8f2defd7 __CFRunLoopDoObservers + 391
13 com.apple.CoreFoundation 0x00007fff8f2be5da __CFRunLoopRun + 1178
14 com.apple.CoreFoundation 0x00007fff8f2bded8 CFRunLoopRunSpecific + 296
15 com.apple.HIToolbox 0x00007fff82b34935 RunCurrentEventLoopInMode + 235
16 com.apple.HIToolbox 0x00007fff82b3476f ReceiveNextEventCommon + 432
17 com.apple.HIToolbox 0x00007fff82b345af _BlockUntilNextEventMatchingListInModeWithFilter + 71
18 com.apple.AppKit 0x00007fff84df5df6 _DPSNextEvent + 1067
19 com.apple.AppKit 0x00007fff84df5226 -[NSApplication _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 454
20 com.apple.AppKit 0x00007fff84de9d80 -[NSApplication run] + 682
21 QtGui 0x00000001051ef967 QEventDispatcherMac::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 1991
22 QtCore 0x000000010adc6384 QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 68
23 QtCore 0x000000010adc6734 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 324
24 QtCore 0x000000010adc8fac QCoreApplication::exec() + 188
25 Pix4Dmapper 0x0000000102866bbb 0x102856000 + 68539
26 Pix4Dmapper 0x0000000102865bff 0x102856000 + 64511
27 libdyld.dylib 0x00007fff955a35ad start + 1
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff8e401efa kevent_qos + 10
1 libdispatch.dylib 0x00007fff97d79165 _dispatch_mgr_invoke + 216
2 libdispatch.dylib 0x00007fff97d78dcd _dispatch_mgr_thread + 52
Thread 2:
0 libsystem_kernel.dylib 0x00007fff8e400db6 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff8fa25728 _pthread_cond_wait + 767
2 libc++.1.dylib 0x00007fff8954d68f std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 47
3 Pix4Dmapper 0x0000000102c48d6f 0x102856000 + 4140399
4 Pix4Dmapper 0x0000000102c48ca0 void* std::__1::__thread_proxy<std::__1::tuple<pix4d::key_thread_pool<int>::worker> >(void*) + 96
5 libsystem_pthread.dylib 0x00007fff8fa2499d _pthread_body + 131
6 libsystem_pthread.dylib 0x00007fff8fa2491a _pthread_start + 168
7 libsystem_pthread.dylib 0x00007fff8fa22351 thread_start + 13
Thread 3:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fff8e40107a __select + 10
1 com.apple.CoreFoundation 0x00007fff8f2fc4fa __CFSocketManager + 762
2 libsystem_pthread.dylib 0x00007fff8fa2499d _pthread_body + 131
3 libsystem_pthread.dylib 0x00007fff8fa2491a _pthread_start + 168
4 libsystem_pthread.dylib 0x00007fff8fa22351 thread_start + 13
Thread 4:: QThread
1 QtCore 0x000000010adf8abd qt_safe_select(int, fd_set*, fd_set*, fd_set*, timeval const*) + 141
2 QtCore 0x000000010adfcf54 QEventDispatcherUNIXPrivate::doSelect(QFlags<QEventLoop::ProcessEventsFlag>, timeval*) + 388
3 QtCore 0x000000010adfd414 QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 308
4 QtCore 0x000000010adc6384 QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 68
5 QtCore 0x000000010adc6734 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 324
6 QtCore 0x000000010aca9ee8 QThread::exec() + 312
7 QtCore 0x000000010acad794 QThreadPrivate::start(void*) + 356
8 libsystem_pthread.dylib 0x00007fff8fa2499d _pthread_body + 131
9 libsystem_pthread.dylib 0x00007fff8fa2491a _pthread_start + 168
10 libsystem_pthread.dylib 0x00007fff8fa22351 thread_start + 13
Thread 5:: QThread
1 QtCore 0x000000010adf8bb4 qt_safe_select(int, fd_set*, fd_set*, fd_set*, timeval const*) + 388
Thread 6:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x00007fff8e3faf72 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff8e3fa3b3 mach_msg + 55
2 com.apple.CoreFoundation 0x00007fff8f2bf1c4 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fff8f2be68c __CFRunLoopRun + 1356
5 com.apple.AppKit 0x00007fff84f4bd95 _NSEventThread + 149
6 libsystem_pthread.dylib 0x00007fff8fa2499d _pthread_body + 131
7 libsystem_pthread.dylib 0x00007fff8fa2491a _pthread_start + 168
8 libsystem_pthread.dylib 0x00007fff8fa22351 thread_start + 13
Thread 7:
2 QtScript 0x00000001087dbc76 QTWTF::TCMalloc_PageHeap::scavengerThread() + 118
3 QtScript 0x00000001087dbcb9 QTWTF::TCMalloc_PageHeap::runScavengerThread(void*) + 9
4 libsystem_pthread.dylib 0x00007fff8fa2499d _pthread_body + 131
5 libsystem_pthread.dylib 0x00007fff8fa2491a _pthread_start + 168
6 libsystem_pthread.dylib 0x00007fff8fa22351 thread_start + 13
Thread 8:: QThread
Thread 9:
2 QtWebKit 0x0000000106e74875 WTF::TCMalloc_PageHeap::scavengerThread() + 117
3 QtWebKit 0x0000000106e74b09 WTF::TCMalloc_PageHeap::runScavengerThread(void*) + 9
Thread 10:
0 libsystem_kernel.dylib 0x00007fff8e4015e2 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff8fa24578 _pthread_wqthread + 1283
2 libsystem_pthread.dylib 0x00007fff8fa22341 start_wqthread + 13
Thread 11:
Thread 12:: Dispatch queue: NSCGSDisableUpdates
2 com.apple.CoreGraphics 0x00007fff94141d96 _CGSReenableUpdateForConnection + 92
3 com.apple.CoreGraphics 0x00007fff94141a69 CGSReenableUpdateToken + 469
4 libdispatch.dylib 0x00007fff97d7e93d _dispatch_call_block_and_release + 12
5 libdispatch.dylib 0x00007fff97d7340b _dispatch_client_callout + 8
6 libdispatch.dylib 0x00007fff97d7803b _dispatch_queue_drain + 754
7 libdispatch.dylib 0x00007fff97d7e707 _dispatch_queue_invoke + 549
8 libdispatch.dylib 0x00007fff97d7340b _dispatch_client_callout + 8
9 libdispatch.dylib 0x00007fff97d7729b _dispatch_root_queue_drain + 1890
10 libdispatch.dylib 0x00007fff97d76b00 _dispatch_worker_thread3 + 91
11 libsystem_pthread.dylib 0x00007fff8fa244de _pthread_wqthread + 1129
12 libsystem_pthread.dylib 0x00007fff8fa22341 start_wqthread + 13
Thread 13:: QThread
Thread 14:: QThread
0 libsystem_kernel.dylib 0x00007fff8e40110a __semwait_signal + 10
1 libsystem_c.dylib 0x00007fff8783fd0f nanosleep + 199
2 libc++.1.dylib 0x00007fff8958c020 std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > const&) + 75
3 libcore.dylib 0x0000000108f72095 pix4d::Worker::manage(pix4d::Worker&, QString const&, unsigned long) + 725
4 Pix4Dmapper 0x0000000102bd584d 0x102856000 + 3668045
5 Pix4Dmapper 0x00000001029b0162 0x102856000 + 1417570
6 Pix4Dmapper 0x00000001029ae0e8 0x102856000 + 1409256
Thread 15:
3 libcore.dylib 0x0000000108f7167e pix4d::Worker::run() + 1086
4 libcore.dylib 0x0000000108f72bc1 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::__bind<void (pix4d::Worker::*)(), pix4d::Worker*> > >(void*) + 113
Thread 16:
4 Pix4Dmapper 0x0000000102dba6f2 0x102856000 + 5654258
5 Pix4Dmapper 0x0000000102db59a2 0x102856000 + 5634466
6 libcore.dylib 0x0000000108f73979 std::__1::__function::__func<pix4d::Worker::run()::\_0, std::\_\_1::allocator\<pix4d::Worker::run()::_0>, void ()>::operator()() + 73
7 libcore.dylib 0x0000000108f73311 pix4d::key_thread_pool<int>::worker::operator()() + 609
8 libcore.dylib 0x0000000108f73070 void* std::__1::__thread_proxy<std::__1::tuple<pix4d::key_thread_pool<int>::worker> >(void*) + 96
9 libsystem_pthread.dylib 0x00007fff8fa2499d _pthread_body + 131
10 libsystem_pthread.dylib 0x00007fff8fa2491a _pthread_start + 168
11 libsystem_pthread.dylib 0x00007fff8fa22351 thread_start + 13
Thread 17:
Thread 18:
4 Pix4Dmapper 0x00000001032a872f 0x102856000 + 10823471
5 Pix4Dmapper 0x00000001032a69b2 0x102856000 + 10815922
Thread 19:
2 libomp.dylib 0x000000010be8f6fb __kmp_launch_monitor(void*) + 1211
3 libsystem_pthread.dylib 0x00007fff8fa2499d _pthread_body + 131
4 libsystem_pthread.dylib 0x00007fff8fa2491a _pthread_start + 168
5 libsystem_pthread.dylib 0x00007fff8fa22351 thread_start + 13
Thread 20:
2 libomp.dylib 0x000000010be91ba3 __kmp_suspend_64 + 371
3 libomp.dylib 0x000000010bea01f7 kmp_flag_64::wait(kmp_info*, int, void*) + 615
4 libomp.dylib 0x000000010be9e0d6 __kmp_hyper_barrier_release(barrier_type, kmp_info*, int, int, int, void*) + 150
5 libomp.dylib 0x000000010be9fdab __kmp_fork_barrier(int, int) + 411
6 libomp.dylib 0x000000010be7949c __kmp_launch_thread + 92
7 libomp.dylib 0x000000010be8e981 __kmp_launch_worker(void*) + 849
Thread 21:
Thread 22:
Thread 23:
4 Pix4Dmapper 0x00000001032c9417 0x102856000 + 10957847
5 Pix4Dmapper 0x00000001032c7fb1 0x102856000 + 10952625
Thread 24:
Thread 25:
Thread 26 Crashed:
0 Pix4Dmapper 0x000000010326052c 0x102856000 + 10528044
1 Pix4Dmapper 0x000000010325fb99 0x102856000 + 10525593
2 libcore.dylib 0x0000000108f73979 std::__1::__function::__func<pix4d::Worker::run()::\_0, std::\_\_1::allocator\<pix4d::Worker::run()::_0>, void ()>::operator()() + 73
3 libcore.dylib 0x0000000108f73311 pix4d::key_thread_pool<int>::worker::operator()() + 609
4 libcore.dylib 0x0000000108f73070 void* std::__1::__thread_proxy<std::__1::tuple<pix4d::key_thread_pool<int>::worker> >(void*) + 96
Thread 26 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000053 rbx: 0x0000000000000013 rcx: 0x00007fc6bc8a5bc0 rdx: 0x0000000000000050
rdi: 0x00007fc6bc8a5bd8 rsi: 0x0000000000000050 rbp: 0x000070000136bdd0 rsp: 0x000070000136bc10
r8: 0x0000000000000001 r9: 0x00007fc6b8909f18 r10: 0x00007fc6b8bf5040 r11: 0xffffffff00000000
r12: 0x0000000000001ae8 r13: 0x00000000000006ba r14: 0x00007000009c9b48 r15: 0x00007000009c9d40
rip: 0x000000010326052c rfl: 0x0000000000010206 cr2: 0x000000010326a000
Logical CPU: 0
Error Code: 0x0200014e
Trap Number: 133
Binary Images:
0x102856000 - 0x103da8ff7 +Pix4Dmapper (2.2.25 - 2.2.25) <A46B200A-3464-3D43-A048-3C8848178402> /Applications/Pix4Dmapper.app/Contents/MacOS/Pix4Dmapper
0x1040c6000 - 0x104106fff com.apple.glut (3.6.3 - GLUT-3.6.3) <845DFCC7-5F30-318B-A2BB-6AA0830A37A0> /System/Library/Frameworks/GLUT.framework/Versions/A/GLUT
0x10417f000 - 0x1041effff +libmesh.dylib (0) <8E15F13C-87DE-3495-925D-4B5BDB37AB2D> /Applications/Pix4Dmapper.app/Contents/Frameworks/libmesh.dylib
0x10422a000 - 0x10428cfff +libsurface.dylib (0) <1DD51BA6-2ED0-34BB-9812-94D9E61BBE8A> /Applications/Pix4Dmapper.app/Contents/Frameworks/libsurface.dylib
0x1042ae000 - 0x10432bfff +libarchive.13.dylib (0) <8049F48E-197D-3033-9E8C-5D841DD3E876> /Applications/Pix4Dmapper.app/Contents/Frameworks/libarchive.13.dylib
0x104368000 - 0x104a1ffe7 +libgdal.dylib (0) <E0BF8C91-BB07-3C88-BA60-67B62781FB67> /Applications/Pix4Dmapper.app/Contents/Frameworks/libgdal.dylib
0x104db4000 - 0x104f11ff3 +liblas.3.dylib (0) <C5857298-5306-365A-B682-0CF6A2A429D8> /Applications/Pix4Dmapper.app/Contents/Frameworks/liblas.3.dylib
0x104fa4000 - 0x104fd1ff7 +libastro.3.dylib (0) <3A7B7D93-EFAD-32A3-9268-1902BF5142CD> /Applications/Pix4Dmapper.app/Contents/Frameworks/libastro.3.dylib
0x1050d5000 - 0x105124ff7 +libOpenMeshCore.4.1.dylib (0) <210E4634-22BD-322A-82EB-70FB1A7A0C3C> /Applications/Pix4Dmapper.app/Contents/Frameworks/libOpenMeshCore.4.1.dylib
0x105157000 - 0x105165ff3 +libOpenMeshTools.4.1.dylib (0) <B7A876DC-D953-3AA7-B7A4-DA06EBF590A6> /Applications/Pix4Dmapper.app/Contents/Frameworks/libOpenMeshTools.4.1.dylib
0x105176000 - 0x105192fff +libosgQt.130.dylib (0) <B3E00EC8-8926-3750-A7D9-EB9190774A73> /Applications/Pix4Dmapper.app/Contents/Frameworks/libosgQt.130.dylib
0x1051ac000 - 0x105bddff7 +QtGui (4.8.7) <CC6F8CFF-D8A3-0D1F-3A23-CDAF1BC60AA4> /Applications/Pix4Dmapper.app/Contents/Frameworks/QtGui.framework/Versions/4/QtGui
0x105ed6000 - 0x106019fff +QtNetwork (4.8.7) <F6123161-A9AB-AEC4-0D41-65355AF06392> /Applications/Pix4Dmapper.app/Contents/Frameworks/QtNetwork.framework/Versions/4/QtNetwork
0x106085000 - 0x10766bfe7 +QtWebKit (4.9.4) <A1F249FD-BA34-BDC9-ECC8-A80194A34947> /Applications/Pix4Dmapper.app/Contents/Frameworks/QtWebKit.framework/Versions/4/QtWebKit
0x107fb8000 - 0x10809bfff +QtOpenGL (4.8.7) <D22227F4-774C-9D6C-3AA4-92BD352CB78D> /Applications/Pix4Dmapper.app/Contents/Frameworks/QtOpenGL.framework/Versions/4/QtOpenGL
0x1080ec000 - 0x10813cfef +QtSvg (4.8.7) <B3AD7660-DCD9-4DCC-7534-050E786FB856> /Applications/Pix4Dmapper.app/Contents/Frameworks/QtSvg.framework/Versions/4/QtSvg
0x108165000 - 0x1084f9fe7 +QtDeclarative (4.8.7) <5A748917-4508-8007-DCBC-2C6542474009> /Applications/Pix4Dmapper.app/Contents/Frameworks/QtDeclarative.framework/Versions/4/QtDeclarative
0x108682000 - 0x1088dafef +QtScript (4.8.7) <3AC62DCE-CF20-5760-A153-F13C064F6D6E> /Applications/Pix4Dmapper.app/Contents/Frameworks/QtScript.framework/Versions/4/QtScript
0x1089a3000 - 0x108aa8ff7 +QtLocation (1.2.2) <E66FF246-0143-30CB-8E7F-C64D344F025F> /Applications/Pix4Dmapper.app/Contents/Frameworks/QtLocation.framework/Versions/1/QtLocation
0x108b18000 - 0x108c85fff +librelpipe.dylib (0) <7D88856D-5008-353F-9951-8C56241ECFC8> /Applications/Pix4Dmapper.app/Contents/Frameworks/librelpipe.dylib
0x108cf9000 - 0x108d07fff +libaircalib.dylib (0) <E71C2DCA-ED6D-3702-AF37-68627E35403C> /Applications/Pix4Dmapper.app/Contents/Frameworks/libaircalib.dylib
0x108d10000 - 0x108d5dff7 +libfeatures.dylib (0) <4A0412CA-0CFF-396A-A9AF-83C7F7F30F5F> /Applications/Pix4Dmapper.app/Contents/Frameworks/libfeatures.dylib
0x108d7a000 - 0x10900aff3 +libcore.dylib (0) <8A01A0F9-8A0F-3B9A-9D6D-0654C37C395A> /Applications/Pix4Dmapper.app/Contents/Frameworks/libcore.dylib
0x1090d0000 - 0x109141fe7 +libgmp.10.dylib (0) <DDCA21A1-A76F-339A-B8AF-EC4333ABA159> /Applications/Pix4Dmapper.app/Contents/Frameworks/libgmp.10.dylib
0x10915b000 - 0x109c0efe7 +libavcodec.56.dylib (0) <926ECE40-3B09-3ED9-B8E9-C6FCFA484439> /Applications/Pix4Dmapper.app/Contents/Frameworks/libavcodec.56.dylib
0x10a366000 - 0x10a4d7ff7 +libavformat.56.dylib (0) <60C4C536-0019-3653-BE4B-C584354C077C> /Applications/Pix4Dmapper.app/Contents/Frameworks/libavformat.56.dylib
0x10a523000 - 0x10a5fafff +libavfilter.5.dylib (0) <845F1583-232D-31E3-A7E3-C05D6E2E7911> /Applications/Pix4Dmapper.app/Contents/Frameworks/libavfilter.5.dylib
0x10a645000 - 0x10a685ff7 +libavutil.54.dylib (0) <708AD2EB-5F9E-3B70-B1F5-034719357686> /Applications/Pix4Dmapper.app/Contents/Frameworks/libavutil.54.dylib
0x10a6af000 - 0x10a73eff7 +libswscale.3.dylib (0) <3653E747-0C92-3AC2-B052-E14EC6893264> /Applications/Pix4Dmapper.app/Contents/Frameworks/libswscale.3.dylib
0x10a759000 - 0x10a902ff3 +libexiv2.14.dylib (0) <C7C0C6B5-8541-3790-A543-4FA68634220E> /Applications/Pix4Dmapper.app/Contents/Frameworks/libexiv2.14.dylib
0x10aa07000 - 0x10abfeffb +libceres.1.dylib (0) <2B49E793-6BF3-3708-B1F5-9ED99D29C018> /Applications/Pix4Dmapper.app/Contents/Frameworks/libceres.1.dylib
0x10ac83000 - 0x10ac83ff7 +cl_kernels (???) <718F9BE8-967A-45BB-8F4B-287EA1B0D850> cl_kernels
0x10ac85000 - 0x10af5ffff +QtCore (4.8 - 4.8.7) <1587CD48-DAD6-622D-3DCA-AF93CD2D02FC> /Applications/Pix4Dmapper.app/Contents/Frameworks/QtCore.framework/Versions/4/QtCore
0x10b013000 - 0x10b052fef +QtXml (4.8.7) <F3BDB2AA-823C-817C-78D9-3E2B083BBF3E> /Applications/Pix4Dmapper.app/Contents/Frameworks/QtXml.framework/Versions/4/QtXml
0x10b074000 - 0x10b523ff7 +QtXmlPatterns (4.8.7) <BC274BE0-A244-27D2-A128-4ABE70B59023> /Applications/Pix4Dmapper.app/Contents/Frameworks/QtXmlPatterns.framework/Versions/4/QtXmlPatterns
0x10b6be000 - 0x10b89cffb +libosg.130.dylib (0) <72E04074-E81D-3C00-9D69-913A3AB6BB0C> /Applications/Pix4Dmapper.app/Contents/Frameworks/libosg.130.dylib
0x10b969000 - 0x10ba20ff3 +libosgDB.130.dylib (0) <791F4DE9-C7A7-3C0C-8B13-30FEFC2A81AF> /Applications/Pix4Dmapper.app/Contents/Frameworks/libosgDB.130.dylib
0x10ba92000 - 0x10bba6ff7 +libosgUtil.130.dylib (0) <38CCA0FA-CCFF-3B5F-90C4-A6BFF2E8EA96> /Applications/Pix4Dmapper.app/Contents/Frameworks/libosgUtil.130.dylib
0x10bc45000 - 0x10bc7dff3 +libosgGA.130.dylib (0) <76BA84EB-60D2-3EBF-B5F5-2BD4076402B4> /Applications/Pix4Dmapper.app/Contents/Frameworks/libosgGA.130.dylib
0x10bccb000 - 0x10bd66ffb +libosgViewer.130.dylib (0) <7C2B5939-3A38-324C-BCF3-168F6CC48065> /Applications/Pix4Dmapper.app/Contents/Frameworks/libosgViewer.130.dylib
0x10bdc9000 - 0x10bdf5ffb +libosgManipulator.130.dylib (0) <F2485424-037E-307B-90F7-0D67E14E5B4B> /Applications/Pix4Dmapper.app/Contents/Frameworks/libosgManipulator.130.dylib
0x10be16000 - 0x10be19ff7 +libOpenThreads.20.dylib (0) <3D499A30-6CF7-3112-98D9-9A2F603DB985> /Applications/Pix4Dmapper.app/Contents/Frameworks/libOpenThreads.20.dylib
0x10be22000 - 0x10be3efff +libfoundation.dylib (0) <DCE65DF3-C9F4-36AB-9580-CBC87A19662E> /Applications/Pix4Dmapper.app/Contents/Frameworks/libfoundation.dylib
0x10be62000 - 0x10bebaff7 +libomp.dylib (0) <E88E5C6E-8A0F-3658-B3A4-D2E25B416B12> /Applications/Pix4Dmapper.app/Contents/Frameworks/libomp.dylib
0x10beea000 - 0x10c98cfff +libfbxsdk.dylib (0) <F3CD7CF1-C1F9-349A-B99D-2134C341C2D3> /Applications/Pix4Dmapper.app/Contents/Frameworks/libfbxsdk.dylib
0x10cd2c000 - 0x10cd45fff libexpat.1.dylib (12.60.1) <6BF318AC-F90F-3F16-99C2-6ADDE404E280> /usr/lib/libexpat.1.dylib
0x10cd51000 - 0x10cdeffff +libGeographic.14.dylib (0) <D24732CD-F1F1-33C0-B104-2C7C2DFFF1F9> /Applications/Pix4Dmapper.app/Contents/Frameworks/libGeographic.14.dylib
0x10ce30000 - 0x10ce47fff +libswresample.1.dylib (0) <C99EA531-2EBC-3732-98B7-FE8C24A0DBC9> /Applications/Pix4Dmapper.app/Contents/Frameworks/libswresample.1.dylib
0x10ce52000 - 0x10ce53fff com.apple.VideoDecodeAcceleration (1.1 - 10) <8B971772-F623-3211-8FC8-EAB8F16ECE4A> /System/Library/Frameworks/VideoDecodeAcceleration.framework/Versions/A/VideoDecodeAcceleration
0x10ce5a000 - 0x10ce77fff +libavresample.2.dylib (0) <9B06BE20-3035-301D-B957-77DB31B3E477> /Applications/Pix4Dmapper.app/Contents/Frameworks/libavresample.2.dylib
0x10ce84000 - 0x10cec3ffb +libproj.9.dylib (0) <2C293AE9-05E5-3A84-8051-AA213D53A093> /Applications/Pix4Dmapper.app/Contents/Frameworks/libproj.9.dylib
0x10ceda000 - 0x10cedefff com.apple.agl (3.3.1 - AGL-3.3.1) <4E401980-0F4F-33E2-A0CF-8C7CCF375F24> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x10ceea000 - 0x10cf27ffb +libosgText.130.dylib (0) <61BD032B-3CBD-3608-BC03-57DB1F040385> /Applications/Pix4Dmapper.app/Contents/Frameworks/libosgText.130.dylib
0x10cf4a000 - 0x10cf84ff3 +libosgWidget.130.dylib (0) <305300DE-E61D-3D5E-93D3-C881A2A11673> /Applications/Pix4Dmapper.app/Contents/Frameworks/libosgWidget.130.dylib
0x10cfbb000 - 0x10cff2ff7 +QtSql (4.8.7) <90A495CB-2947-5816-EE55-D7B34194B9FE> /Applications/Pix4Dmapper.app/Contents/Frameworks/QtSql.framework/Versions/4/QtSql
0x10d00e000 - 0x10d27dff7 +libopencv_core.3.1.dylib (0) <22ED53BE-6790-3A21-9EB9-8A568B691B71> /Applications/Pix4Dmapper.app/Contents/Frameworks/libopencv_core.3.1.dylib
0x10d2e6000 - 0x10d534ffb +libopencv_imgproc.3.1.dylib (0) <E06CF821-AF2E-3655-A777-07B0B6CBD450> /Applications/Pix4Dmapper.app/Contents/Frameworks/libopencv_imgproc.3.1.dylib
0x10d63a000 - 0x10d678ffb +libopencv_aruco.3.1.dylib (0) <13CD670B-CA56-3C43-B770-D205B91652A6> /Applications/Pix4Dmapper.app/Contents/Frameworks/libopencv_aruco.3.1.dylib
0x10d6a1000 - 0x10d6abff7 +libopencv_highgui.3.1.dylib (0) <1A1DC234-F347-3BC1-88FC-425663A4CB5C> /Applications/Pix4Dmapper.app/Contents/Frameworks/libopencv_highgui.3.1.dylib
0x10d6b8000 - 0x10d83bffb +libopencv_calib3d.3.1.dylib (0) <D1651BFE-B14D-3727-8F04-55A27F8B8B05> /Applications/Pix4Dmapper.app/Contents/Frameworks/libopencv_calib3d.3.1.dylib
0x10d864000 - 0x10d8ecff3 +libopencv_features2d.3.1.dylib (0) <1C1173FC-0875-34B2-85E0-45806A8C29B0> /Applications/Pix4Dmapper.app/Contents/Frameworks/libopencv_features2d.3.1.dylib
0x10d912000 - 0x10d965fff +libopencv_flann.3.1.dylib (0) <4419D0BC-1A20-31D5-A3C7-42372CB51C1E> /Applications/Pix4Dmapper.app/Contents/Frameworks/libopencv_flann.3.1.dylib
0x10d98f000 - 0x10da2bffb +libopencv_ml.3.1.dylib (0) <49FD26F3-4DF7-3B9E-ADD7-D0C3AB25545B> /Applications/Pix4Dmapper.app/Contents/Frameworks/libopencv_ml.3.1.dylib
0x10da4b000 - 0x10da61ffb +libopencv_videoio.3.1.dylib (0) <2A5CD709-7202-3655-9F2D-4361FC236298> /Applications/Pix4Dmapper.app/Contents/Frameworks/libopencv_videoio.3.1.dylib
0x10da70000 - 0x10da8eff3 +libopencv_imgcodecs.3.1.dylib (0) <B8DE65C8-939F-327C-8743-C84876FCFED7> /Applications/Pix4Dmapper.app/Contents/Frameworks/libopencv_imgcodecs.3.1.dylib
0x10ddf6000 - 0x10ddf8fff libCGXType.A.dylib (960.3) <70FA6D91-53BC-3DA6-92F3-7FEB33C73948> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x10fe6b000 - 0x10fe86fff com.apple.security.csparser (3.0 - 57337.60.2) <EE79884A-DBF8-340D-96D2-F92FE4E66C67> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/csparser
0x10fe9a000 - 0x10fec3ffb libRIP.A.dylib (960.3) <702967FB-D16C-38C7-A3CC-0EC336740A69> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x10ff51000 - 0x10fff6fff ColorSyncDeprecated.dylib (470.3) <A30CB963-667F-39D0-8537-66FCC820F5A6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x110be9000 - 0x110c01fe7 +libqcorewlanbearer.dylib (0) <0649018C-B42F-EF97-B2FF-B49C1377248D> /Applications/Pix4Dmapper.app/Contents/MacOS/bearer/libqcorewlanbearer.dylib
0x110c10000 - 0x110c1bfff +libqgenericbearer.dylib (0) <DF5FA216-35CE-A18C-7E49-AD8244EF5DDC> /Applications/Pix4Dmapper.app/Contents/MacOS/bearer/libqgenericbearer.dylib
0x115259000 - 0x115293fff +libqtgeoservices_nokia.dylib (0) <D8F2D26F-CB99-36AC-8919-F82E7E79DC99> /Applications/Pix4Dmapper.app/Contents/MacOS/geoservices/libqtgeoservices_nokia.dylib
0x115488000 - 0x1154a5ff7 +libqtgeoservices_osm.dylib (0) <EF3F8FDB-6FAD-3DDF-B69F-50D6F87F5570> /Applications/Pix4Dmapper.app/Contents/MacOS/geoservices/libqtgeoservices_osm.dylib
0x1154b4000 - 0x1154c4ff7 +libqtgeoservices_tiles.dylib (0) <A0FBFB35-BDF1-3084-8974-4C3AD4551D58> /Applications/Pix4Dmapper.app/Contents/MacOS/geoservices/libqtgeoservices_tiles.dylib
0x1166ac000 - 0x1166b2ff7 +libqgif.dylib (0) <6564A7DF-8AB3-8EFA-6D88-01758AA543A5> /Applications/Pix4Dmapper.app/Contents/MacOS/imageformats/libqgif.dylib
0x1166ba000 - 0x1166c0ff7 +libqico.dylib (0) <C4467424-AC40-F0DA-BEE0-6F4A8A7BC94D> /Applications/Pix4Dmapper.app/Contents/MacOS/imageformats/libqico.dylib
0x1166c8000 - 0x116703ff7 +libqjpeg.dylib (0) <690AC3EE-FEB6-6637-95BA-936E099D6E2E> /Applications/Pix4Dmapper.app/Contents/MacOS/imageformats/libqjpeg.dylib
0x116710000 - 0x116764fe7 +libqmng.dylib (0) <6C5AEE56-0868-1688-07E9-119DE7DE4D8F> /Applications/Pix4Dmapper.app/Contents/MacOS/imageformats/libqmng.dylib
0x116779000 - 0x11677dff7 +libqsvg.dylib (0) <F2B70F34-1C41-1D8A-C460-7F988FBF0799> /Applications/Pix4Dmapper.app/Contents/MacOS/imageformats/libqsvg.dylib
0x116785000 - 0x116789fff +libqtga.dylib (0) <9DE24A98-3584-C61E-9D16-F1C4664E3408> /Applications/Pix4Dmapper.app/Contents/MacOS/imageformats/libqtga.dylib
0x116790000 - 0x1167f2fff +libqtiff.dylib (0) <2F7A5C7C-7C38-1771-45D6-E36834D07342> /Applications/Pix4Dmapper.app/Contents/MacOS/imageformats/libqtiff.dylib
0x116850000 - 0x116859fff +libqsvgicon.dylib (0) <8D7EF0DF-57B9-93B9-5E52-35D1E7C04013> /Applications/Pix4Dmapper.app/Contents/MacOS/iconengines/libqsvgicon.dylib
0x118b45000 - 0x118b48ff3 libCGXCoreImage.A.dylib (960.3) <8DA6B68D-951C-3B71-A63B-2197A71E6FEE> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0x118b63000 - 0x118b64ff7 +cl_kernels (???) <0C713D26-7B48-44AB-BD69-7098C4599D7E> cl_kernels
0x7fff62df8000 - 0x7fff62e2fa47 dyld (360.22) <DC81CC9D-651A-3A45-8809-928282052BD3> /usr/lib/dyld
0x7fff81e14000 - 0x7fff8217f657 libobjc.A.dylib (680) <D55D5807-1FBE-32A5-9105-44D7AFE68C27> /usr/lib/libobjc.A.dylib
0x7fff8220b000 - 0x7fff82269fff com.apple.SystemConfiguration (1.14 - 1.14) <D801FAD7-5A2D-3E5E-9F44-B6C9B8BEA747> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff82289000 - 0x7fff82289fff com.apple.ApplicationServices (48 - 48) <ADD57D3A-142F-3EF5-BFD8-EACD82164884> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff824ed000 - 0x7fff824f8fff com.apple.CrashReporterSupport (10.11 - 718) <05892B57-F2CD-3C84-B984-0417F6B361DB> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff824fb000 - 0x7fff82929fff com.apple.vision.FaceCore (3.3.1 - 3.3.1) <E54028EA-4217-3078-A2B1-C52E4214D59E> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff82b04000 - 0x7fff82df9fff com.apple.HIToolbox (2.1.1 - 807.2) <36413C45-36AF-34EF-9C0E-F18B31D1E565> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff82dfa000 - 0x7fff82e6eff3 com.apple.securityfoundation (6.0 - 55126) <DAA4FDD0-7F84-30AA-BE6F-96BB9F871F07> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff82e76000 - 0x7fff82e87ff7 libz.1.dylib (61.20.1) <B3EBB42F-48E3-3287-9F0D-308E04D407AC> /usr/lib/libz.1.dylib
0x7fff82fca000 - 0x7fff8301bfff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <EA7D4F3B-062B-3C81-A98C-C89264D00D48> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff8301c000 - 0x7fff8306efff com.apple.ImageCaptureCore (7.0 - 7.0) <9F3123D8-29D2-332F-AD6B-AB9BF1A58022> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff83090000 - 0x7fff830b9ff7 libxpc.dylib (765.50.8) <54D1328E-054E-3DAA-89E2-375722F9D18F> /usr/lib/system/libxpc.dylib
0x7fff830ba000 - 0x7fff830bffff com.apple.ImageCapture (9.0 - 9.0) <ACECF0B7-7D92-3A22-BF47-E8FADF4C5378> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff830c0000 - 0x7fff830c9ff7 com.apple.CommonAuth (4.0 - 2.0) <4B8673E1-3697-3FE2-8D30-AC7AC5D4F8BF> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff83345000 - 0x7fff83348ff7 com.apple.help (1.3.3 - 46) <35DA4D48-0BC2-35A1-8D7C-40905CDF4F64> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff83349000 - 0x7fff83350ff7 com.apple.phonenumbers (1.1.1 - 105) <A616AFB5-2336-385A-B058-16A423D2B21B> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
0x7fff83351000 - 0x7fff8343cff7 com.apple.QuickLookUIFramework (5.0 - 696.7) <5A4AAFEC-D38C-3DA0-9361-CBF1D4C6B376> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fff834cd000 - 0x7fff834fefff com.apple.GSS (4.0 - 2.0) <B490333A-3B3E-397A-AD75-68846E9A9140> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff834ff000 - 0x7fff83790ff7 com.apple.RawCamera.bundle (6.20 - 856) <C66E7CF9-0352-3A5A-AD2B-DE16136EA6B1> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff83791000 - 0x7fff837abfff com.apple.Kerberos (3.0 - 1) <1B4744BF-E5AE-38E2-AA56-E22D3270F2E8> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff83816000 - 0x7fff83818fff libCVMSPluginSupport.dylib (12.1) <D81B3D8D-B83F-3918-BD4B-6C794A30AF9F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff83887000 - 0x7fff8389cfff com.apple.AppContainer (4.0 - 261.40.2) <F220E702-1C00-3BD2-9943-C7E75C3B4418> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff838bf000 - 0x7fff838c7fff libMatch.1.dylib (27) <3AC0BFB8-7E69-3DBE-A175-7F3946FC4554> /usr/lib/libMatch.1.dylib
0x7fff838c8000 - 0x7fff838d8ff3 com.apple.ProtocolBuffer (1 - 243) <BAE5E5C9-DD59-3BB8-9741-EEFC5E3046EE> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff838d9000 - 0x7fff838f4ff7 libCRFSuite.dylib (34) <078B4CD8-6A8C-3067-B2BA-0C2A0BAB8AC3> /usr/lib/libCRFSuite.dylib
0x7fff838f5000 - 0x7fff83b16ff7 com.apple.CoreImage (11.4.0 - 366.4.19) <F5B7B115-E43A-3C61-A6AD-EFCDE7FC43A1> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff83b26000 - 0x7fff83b26fff com.apple.CoreServices (728.13 - 728.13) <E3DFECD2-ECEA-3242-972D-95B9646B57B8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff83b27000 - 0x7fff83b69ff7 com.apple.Metal (56.6 - 56.6) <30518711-8D00-3759-AA19-800D3C88E693> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff83b6a000 - 0x7fff83b74fff com.apple.NetAuth (6.0 - 6.0) <D692B1EF-534F-3892-8E2F-2BBA7C8AFD74> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff83c3b000 - 0x7fff83c4bfff libbsm.0.dylib (34) <7E14504C-A8B0-3574-B6EB-5D5FABC72926> /usr/lib/libbsm.0.dylib
0x7fff83e61000 - 0x7fff83eadfff com.apple.print.framework.PrintCore (11.2 - 472.2) <5AE8AA6B-CE09-397D-B0D4-0F9CCBF1F77D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff842d9000 - 0x7fff842e4fff com.apple.AppSandbox (4.0 - 261.40.2) <52766210-B6EB-3B73-AB1B-42E0A9AD2EE8> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fff846a9000 - 0x7fff846acfff libCoreVMClient.dylib (119.5) <560D70FB-709F-3030-96C9-F249FCB7DA6D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff846af000 - 0x7fff846deff7 com.apple.DictionaryServices (1.2 - 250.3) <30250542-CBAA-39C1-91AA-B57A5DE17594> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff846fb000 - 0x7fff846fbff7 libunc.dylib (29) <DDB1E947-C775-33B8-B461-63E5EB698F0E> /usr/lib/system/libunc.dylib
0x7fff84740000 - 0x7fff8474efff com.apple.opengl (12.1.0 - 12.1.0) <0718DB60-BA4F-3CF7-A117-10A2515D931F> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff8474f000 - 0x7fff84752fff libsystem_sandbox.dylib (460.60.2) <2A68B39C-B786-3A05-87A2-56E688469FB8> /usr/lib/system/libsystem_sandbox.dylib
0x7fff84753000 - 0x7fff8475eff7 libChineseTokenizer.dylib (16) <79B8C67A-3061-3C78-92CD-4650719E68D4> /usr/lib/libChineseTokenizer.dylib
0x7fff8475f000 - 0x7fff8476afff com.apple.DirectoryService.Framework (10.11 - 194) <6F827D0E-0F02-3B09-B2A8-252865EECA7F> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff8476b000 - 0x7fff84780ff3 libCGInterfaces.dylib (317.9) <473434E1-5269-3077-A047-D05E024AE631> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff84781000 - 0x7fff84786ff7 com.apple.AssetCacheServices (14.1 - 14.1) <5F249F84-660A-3E94-B073-6729E7ED56D9> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServices
0x7fff84787000 - 0x7fff847abfff com.apple.quartzfilters (1.10.0 - 1.10.0) <F5C482E2-5AFB-3959-8C01-C149D48E7583> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fff847ac000 - 0x7fff847c3ff7 libsystem_coretls.dylib (83.40.5) <C90DAE38-4082-381C-A185-2A6A8B677628> /usr/lib/system/libsystem_coretls.dylib
0x7fff847c4000 - 0x7fff847d7fff com.apple.contacts.ContactsPersistence (1.0 - 2137.1) <71232F20-11BD-370D-9F43-F262BFE46C93> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
0x7fff847fa000 - 0x7fff84d38ff7 com.apple.MediaToolbox (1.0 - 1731.15.206) <119FFD0E-947D-3103-9221-458439F5764D> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff84d42000 - 0x7fff84d6dffb libarchive.2.dylib (33.20.2) <6C370A21-63FD-3A68-B4B3-5333F24B770B> /usr/lib/libarchive.2.dylib
0x7fff84d6e000 - 0x7fff84d6efff libOpenScriptingUtil.dylib (169.1) <AD0DAC8A-9849-3077-999F-9AEC6112BDAB> /usr/lib/libOpenScriptingUtil.dylib
0x7fff84d6f000 - 0x7fff84dacff3 com.apple.bom (14.0 - 193.7) <9B8AE30B-24A3-37AB-B04E-4CE67AED4775> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff84dad000 - 0x7fff859d6ff7 com.apple.AppKit (6.9 - 1404.47) <F3411F6E-DD87-34D0-8C68-C69B2205E41D> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff859d7000 - 0x7fff85ab0fff com.apple.CoreMedia (1.0 - 1731.15.206) <DE407384-39D5-3727-A78D-D22849D816C7> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff86b9b000 - 0x7fff86ba6ff7 libcommonCrypto.dylib (60075.50.1) <93732261-34B4-3914-B7A2-90A81A182DBA> /usr/lib/system/libcommonCrypto.dylib
0x7fff86ba7000 - 0x7fff86bbbfff com.apple.CoreDuetDaemonProtocol (1.0 - 1) <1D60D60C-914A-3BAB-8607-79F68F4C712E> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
0x7fff86be2000 - 0x7fff86c42fff com.apple.QuickLookFramework (5.0 - 696.7) <ECD33169-5EB1-3783-AF9E-1AB9240F8358> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff86c51000 - 0x7fff86c6bff3 liblzma.5.dylib (10) <CC03591B-FA57-3CA5-AC81-0D76033AC0CE> /usr/lib/liblzma.5.dylib
0x7fff86c71000 - 0x7fff86c71fff com.apple.Cocoa (6.11 - 22) <807787AB-D231-3F51-A99B-A9314623C571> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff86e05000 - 0x7fff86e0dfff libcopyfile.dylib (127) <A48637BC-F3F2-34F2-BB68-4C65FD012832> /usr/lib/system/libcopyfile.dylib
0x7fff86e0e000 - 0x7fff86e60fff com.apple.AppleVAFramework (5.0.32 - 5.0.32) <271ED7A9-73E5-3595-A8D6-28594C9F3C9D> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff86e68000 - 0x7fff86ec4fff com.apple.Suggestions (5.0 - 180) <450BCB58-786F-37DC-9AC7-2E3D13198032> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
0x7fff86ec5000 - 0x7fff86ec7ff7 libsystem_configuration.dylib (802.40.13) <3DEB7DF9-6804-37E1-BC83-0166882FF0FF> /usr/lib/system/libsystem_configuration.dylib
0x7fff86ec8000 - 0x7fff86ecdff3 libunwind.dylib (35.3) <F6EB48E5-4D12-359A-AB54-C937FBBE9043> /usr/lib/system/libunwind.dylib
0x7fff86ece000 - 0x7fff86f86ff7 com.apple.CoreDuet (1.0 - 1) <FC1EAEE1-73A4-3B13-A634-1D2A94D0C0B7> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
0x7fff86f87000 - 0x7fff86fabff7 libJPEG.dylib (1459) <30F85216-E836-37B3-874E-62F1D040B098> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff86fac000 - 0x7fff86fb4ffb libsystem_dnssd.dylib (625.60.4) <80189998-32B0-316C-B5C5-53857486713D> /usr/lib/system/libsystem_dnssd.dylib
0x7fff86fb7000 - 0x7fff8703bffb com.apple.AVKit (1.1 - 285.10) <F8C27415-3105-37A0-8959-F5560144FBB1> /System/Library/Frameworks/AVKit.framework/Versions/A/AVKit
0x7fff8703c000 - 0x7fff87065fff libsystem_info.dylib (477.50.4) <FAA9226D-64DE-3769-A6D8-6CABA4B7FF4D> /usr/lib/system/libsystem_info.dylib
0x7fff870c5000 - 0x7fff870cdfef libsystem_platform.dylib (74.40.2) <29A905EF-6777-3C33-82B0-6C3A88C4BA15> /usr/lib/system/libsystem_platform.dylib
0x7fff870ce000 - 0x7fff8728effb libBLAS.dylib (1162.2) <B4C21826-5EB3-3C6D-B75D-CA4886E2B6A6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff87293000 - 0x7fff872afff7 libextension.dylib (78) <FD952DA6-BBEC-3CB6-98B3-E1D111C5C54E> /usr/lib/libextension.dylib
0x7fff872b0000 - 0x7fff87369ff7 libvMisc.dylib (563.5) <BF612F7D-FA3B-3F9F-8BE7-8D1BCB21ECC5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff8736a000 - 0x7fff8736cff7 libRadiance.dylib (1459) <1FE4F408-D135-3CA5-A06B-B0FCE974997C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff8736d000 - 0x7fff87373ff7 com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <9E5A980A-F455-32D5-BBEE-3BD6018CC45E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff87374000 - 0x7fff873a0fff com.apple.framework.SystemAdministration (1.0 - 1.0) <1318B6A5-FFC3-3615-914D-95CBFE5BA727> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x7fff873a1000 - 0x7fff874afff3 com.apple.desktopservices (1.10.3 - 1.10.3) <3A6906D4-C0B8-30D1-B589-0466E5E42B69> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff87635000 - 0x7fff8765fff7 libc++abi.dylib (307.2) <922EFB36-0E9E-315B-8270-E81AC43472C0> /usr/lib/libc++abi.dylib
0x7fff876d2000 - 0x7fff87738ff7 libsystem_network.dylib (583.50.1) <B52DAB73-92DC-3DA7-B9F4-B899D66445C1> /usr/lib/system/libsystem_network.dylib
0x7fff8773c000 - 0x7fff8773ffff com.apple.IOSurface (108.2.3 - 108.2.3) <52E51D16-42E9-3DDB-A16C-48225EF262C4> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff87740000 - 0x7fff87742ff7 com.apple.securityhi (9.0 - 55006) <1E7BE52B-97EA-371A-AECA-1EE2AD246D8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff8775f000 - 0x7fff877b4fff com.apple.AE (701 - 701) <AD492742-F884-386B-A450-FAC281B9FFA4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff877b5000 - 0x7fff877b7ff7 com.apple.SafariServices.framework (11601 - 11601.7.8) <6BA896E7-ADFC-32D1-90B3-C2691963F1F5> /System/Library/PrivateFrameworks/SafariServices.framework/Versions/A/SafariServices
0x7fff877bb000 - 0x7fff877bffff com.apple.CommonPanels (1.2.6 - 96) <4AE7E5AE-55B3-37FA-9BDE-B23147ADA2E9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff877c0000 - 0x7fff8784dfef libsystem_c.dylib (1082.60.1) <28733D22-553E-3CBC-8D2C-EDCEB46E46AF> /usr/lib/system/libsystem_c.dylib
0x7fff8785f000 - 0x7fff87895fff libssl.0.9.8.dylib (59.60.1) <C047F10D-A929-36C8-83DE-E8BB7183A158> /usr/lib/libssl.0.9.8.dylib
0x7fff87896000 - 0x7fff87d54fcf com.apple.vImage (8.0 - 8.0) <85FB412E-EB30-3433-A79B-B3970FC83580> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff87d7f000 - 0x7fff87d8afff libcsfde.dylib (517.50.1) <52F0DB6A-13B8-355E-ADFD-72834D3CA183> /usr/lib/libcsfde.dylib
0x7fff87d8b000 - 0x7fff87d99fff com.apple.IntlPreferences (2.0 - 192) <0108A3F2-6A11-30B1-965D-A167CC8131EC> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0x7fff87d9a000 - 0x7fff88040ff7 com.apple.CoreData (120 - 641.3) <A29A5491-6169-372B-828F-84EE0CFD4BC4> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff880a9000 - 0x7fff880bfff7 libLinearAlgebra.dylib (1162.2) <FFE54EDF-F06F-3C0A-864A-4CA7BBFD4B2D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff880f8000 - 0x7fff8821ffff com.apple.LaunchServices (728.13 - 728.13) <DF9A69C3-06AD-3062-A40A-50ED12CA18CA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff8838a000 - 0x7fff885f7fff com.apple.imageKit (2.6 - 932) <FAE317B8-DF15-3096-AFAC-464913BF2F3B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff885f8000 - 0x7fff885fbfff libspindump.dylib (197.1) <48F4C673-9F0C-38BE-B550-88241E812518> /usr/lib/libspindump.dylib
0x7fff88f37000 - 0x7fff89339fff libLAPACK.dylib (1162.2) <42238ED4-6B7A-39D0-BFF2-304A0C287213> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff89362000 - 0x7fff893bdff7 libTIFF.dylib (1459) <CA5015CC-A770-3A62-BABD-B5A88AD390E6> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff893be000 - 0x7fff893f6ff7 com.apple.RemoteViewServices (2.0 - 101) <B2881449-8CFE-3D1C-B4BF-155640392533> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff893f7000 - 0x7fff894b1fff com.apple.DiscRecording (9.0.1 - 9010.4.3) <540853B2-B123-3560-8023-C92EE229051A> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff894c6000 - 0x7fff894c6ff7 libkeymgr.dylib (28) <8371CE54-5FDD-3CE9-B3DF-E98C761B6FE0> /usr/lib/system/libkeymgr.dylib
0x7fff894c7000 - 0x7fff8950cff3 libFontRegistry.dylib (155.2) <A70DD497-35F3-34DA-9C19-F4B90080E961> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff89546000 - 0x7fff89599ff7 libc++.1.dylib (120.1) <8FC3D139-8055-3498-9AC5-6467CB7F4D14> /usr/lib/libc++.1.dylib
0x7fff89759000 - 0x7fff897e1fff com.apple.CoreSymbolication (3.1 - 58048.1) <4730422E-4178-34F9-8550-BB92F2A4F44B> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff897e2000 - 0x7fff8998eff7 com.apple.avfoundation (2.0 - 1046.9.12) <2D241BC4-A619-3382-BABD-C4E4490BD638> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff8998f000 - 0x7fff89d67fef com.apple.CoreAUC (214.0.0 - 214.0.0) <F80C19CA-6CD0-3052-9C22-0288A257CCC8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff89e13000 - 0x7fff89e13fff com.apple.audio.units.AudioUnit (1.13 - 1.13) <378B5292-F216-32AB-B628-8C33A72D7052> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff89e93000 - 0x7fff8a039ff7 com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <370E95BC-956C-3962-86CC-0A14CF6A0389> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff8a03b000 - 0x7fff8a06eff7 com.apple.MediaKit (16 - 809) <BF8032FE-6645-37F6-A622-BC7EEE3EAABF> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff8a099000 - 0x7fff8a738ffb com.apple.JavaScriptCore (11601 - 11601.7.8) <38585ADC-1AD4-3BD2-8972-B90344CE57C0> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff8a7b0000 - 0x7fff8a7b1ff7 libodfde.dylib (23) <F84CB160-D638-3190-B6F5-A262E9AF09F6> /usr/lib/libodfde.dylib
0x7fff8a813000 - 0x7fff8a822fe7 com.apple.AppleFSCompression (81.20.2 - 1.0) <2FE122A9-5265-320A-9600-FFC5CE4DE197> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff8a823000 - 0x7fff8a828fff com.apple.MediaAccessibility (1.0 - 79) <C5E61B45-1967-3602-A48C-31E132B998B2> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff8a829000 - 0x7fff8a82eff7 libheimdal-asn1.dylib (453.40.10) <981DE40B-FA16-36F7-BE92-8C8A115D6CD9> /usr/lib/libheimdal-asn1.dylib
0x7fff8a82f000 - 0x7fff8a837fff com.apple.AppleSRP (5.0 - 1) <840A5C20-6452-36BB-ACF7-29BA6CBF7C48> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff8a843000 - 0x7fff8a843ff7 liblaunch.dylib (765.50.8) <834ED605-5114-3641-AA4D-ECF31B801C50> /usr/lib/system/liblaunch.dylib
0x7fff8a844000 - 0x7fff8a85dfff com.apple.openscripting (1.7.1 - 169.1) <36EBF6A7-334A-3197-838F-E8C7B27FCDBB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff8a85e000 - 0x7fff8a860fff libsystem_coreservices.dylib (19.2) <1B3F5AFC-FFCD-3ECB-8B9A-5538366FB20D> /usr/lib/system/libsystem_coreservices.dylib
0x7fff8a861000 - 0x7fff8a885fff com.apple.MultitouchSupport.framework (304.12 - 304.12) <65CB7653-EACD-3ADB-ABB6-2E0671708301> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff8a886000 - 0x7fff8a891fff libGL.dylib (12.1) <70D51643-04AC-3400-8F11-A6FC25985289> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff8aa4c000 - 0x7fff8aa4efff com.apple.EFILogin (2.0 - 2) <38150198-DD7F-3C73-BCAA-C74BB376393A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff8aa4f000 - 0x7fff8aabefff com.apple.SearchKit (1.4.0 - 1.4.0) <F159A888-34CA-36F1-AC8E-EB1B38C9DFB3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff8aafb000 - 0x7fff8ac45ff7 com.apple.coreui (2.1 - 366.1) <8138636F-A0A7-31C7-896C-5F5747FA1B2A> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff8ac46000 - 0x7fff8ac52fff com.apple.HelpData (2.1.4 - 90) <10608EEC-B613-309C-96E6-5A40AB951FA4> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fff8ac53000 - 0x7fff8ac7afff com.apple.ChunkingLibrary (167 - 167) <AD7F285C-005E-36BB-98A3-5826413533BE> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff8ac7b000 - 0x7fff8aca6ff7 com.apple.AddressBook.ContactsFoundation (8.0 - 2137.1) <BAE70E9D-BCC8-3650-B554-6D646388EDEF> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
0x7fff8b684000 - 0x7fff8b780ff7 libFontParser.dylib (158.6) <267A9AE4-4138-3112-8D73-BDFDC96568FF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff8b8c4000 - 0x7fff8b97dff7 com.apple.cloudkit.CloudKit (482.29 - 482.29) <E235B37E-1491-3857-BDE8-38450D4FE8D0> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff8c1f7000 - 0x7fff8c1faffb libScreenReader.dylib (426.42) <16FC79D1-4573-3E90-945F-CBA22D5185FD> /usr/lib/libScreenReader.dylib
0x7fff8c1fb000 - 0x7fff8c272ff7 com.apple.MMCS (1.3 - 357.1) <549FBEFC-55F7-3101-BF51-A0B1F7CF2B46> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
0x7fff8c3c2000 - 0x7fff8c3c2fff libmetal_timestamp.dylib (600.0.44.2) <DEEA1127-7A5D-3EF2-A4B2-AE125CBA5DB5> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
0x7fff8c411000 - 0x7fff8c41aff7 com.apple.DisplayServicesFW (3.0 - 378) <45BE1B99-8E10-32F0-A180-A6B6CB5883AE> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff8c420000 - 0x7fff8c447fff com.apple.shortcut (2.16 - 93) <2BA6DF3E-04C7-39C8-B311-3413E9FC9022> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fff8c848000 - 0x7fff8c84affb libutil.dylib (43) <4C9BFE8B-563B-3EEA-A323-8F4F14E0A46C> /usr/lib/libutil.dylib
0x7fff8c84b000 - 0x7fff8c84bfff com.apple.quartzframework (1.5 - 21) <5DC3D0D9-9E3F-3AA5-92F1-F229907A49B9> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff8c91d000 - 0x7fff8c926fff com.apple.icloud.FindMyDevice (1.0 - 1) <B9C741F2-6FAC-3BA7-B6E0-9A910C6E8D4E> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
0x7fff8c930000 - 0x7fff8cbcaff3 com.apple.security (7.0 - 57337.60.2) <E2E553E7-28C4-3296-B3B6-BB1B3CA73943> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff8cbcb000 - 0x7fff8cbdcfff libcmph.dylib (6) <BA4BF2C6-7F4E-33B8-9DD7-619C9EB83ECF> /usr/lib/libcmph.dylib
0x7fff8cbdd000 - 0x7fff8cbddfff com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <848125D3-AF14-3526-8745-FFCDB200CD76> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff8cbe3000 - 0x7fff8ccc3ff7 unorm8_rgba.dylib (2.7.3) <9EB6C346-CFF6-32D7-B4A1-2409DFBCB216> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba.dylib
0x7fff8ccc4000 - 0x7fff8cd2fff7 com.apple.framework.CoreWLAN (11.0 - 1101.20) <3B35C543-7FCE-333F-80C1-432FA41DDCDE> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff8cd30000 - 0x7fff8cd7cff7 com.apple.corelocation (1486.17 - 1615.38) <6336CFC5-9D7D-3B76-B263-56DD6EBD0B8D> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fff8cd7d000 - 0x7fff8cd89fff com.apple.CacheDelete (1.0 - 1) <678B521D-5B50-3137-A972-33F2DF1D7A5A> /System/Library/PrivateFrameworks/CacheDelete.framework/Versions/A/CacheDelete
0x7fff8d09c000 - 0x7fff8d10aff7 com.apple.ApplicationServices.ATS (377 - 394.4) <9779E916-0788-3CAC-B1EC-F68BCB12A2B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff8d10b000 - 0x7fff8d10cfff libsystem_blocks.dylib (65) <1244D9D5-F6AA-35BB-B307-86851C24B8E5> /usr/lib/system/libsystem_blocks.dylib
0x7fff8d1e2000 - 0x7fff8d282fff com.apple.ViewBridge (159 - 159) <D8131B7E-DFC9-3FDD-9D56-49821C1D1521> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff8d283000 - 0x7fff8d296fff com.apple.CoreBluetooth (1.0 - 1) <E54CA9A2-A5C6-30C5-9D6E-8472DBA9371E> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff8e34e000 - 0x7fff8e37cff7 libsandbox.1.dylib (460.60.2) <1C3F244B-3273-3148-B500-165DFABBEA8D> /usr/lib/libsandbox.1.dylib
0x7fff8e39d000 - 0x7fff8e3b8fff com.apple.aps.framework (4.0 - 4.0) <CAD47B6E-A581-3B35-885B-67B206F41D5E> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fff8e3ea000 - 0x7fff8e408ff7 libsystem_kernel.dylib (3248.60.11) <A3F069EA-6A41-35CA-BDF8-187E0209B3E2> /usr/lib/system/libsystem_kernel.dylib
0x7fff8e409000 - 0x7fff8e428ff7 com.apple.framework.Apple80211 (11.0 - 1121.34.2) <90477FAE-B835-3931-80FB-FDFF02B21D9D> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff8e42c000 - 0x7fff8e455fff com.apple.ProtectedCloudStorage (1.0 - 1) <7436B2B3-943A-3500-B099-80F133B3E002> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff8e456000 - 0x7fff8e457fff liblangid.dylib (122) <9CC4F0D1-5C51-3B69-BC8F-EE3A51FD0822> /usr/lib/liblangid.dylib
0x7fff8e611000 - 0x7fff8e633fff com.apple.IconServices (68.1 - 68.1) <CDEEDBE6-F53B-3BA1-82D4-23BCA3DD8949> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff8e64c000 - 0x7fff8e6f3fff com.apple.LanguageModeling (1.0 - 1) <58C18A47-BDE7-3CBE-81C0-797029D170A1> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff8e6f4000 - 0x7fff8e806fef libvDSP.dylib (563.5) <5702650E-DF08-3D58-B16F-9EF0A28702B3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff8e817000 - 0x7fff8e823fff com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) <71DA00B8-5EA2-326B-8814-59DB25512F65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff8e824000 - 0x7fff8e827ff7 libCoreFSCache.dylib (119.5) <2389D7DA-B8EF-3EB4-AAAF-FBEDE01CDECA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff8e835000 - 0x7fff8e8cbfff com.apple.ColorSync (4.9.0 - 4.9.0) <8FC37E20-6579-3CB2-9D49-BC39FC38DF87> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff8e936000 - 0x7fff8e94ffe7 libcompression.dylib (28) <F83F421D-115D-3457-A9AA-1BEB5070A30B> /usr/lib/libcompression.dylib
0x7fff8e950000 - 0x7fff8e95fffb com.apple.LangAnalysis (1.7.0 - 1.7.0) <18D21123-A3E7-3851-974A-08E5D4540475> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff8e960000 - 0x7fff8e985ff7 libPng.dylib (1459) <F98F6D50-BC82-3ED7-885F-FEE708E401CC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff8e986000 - 0x7fff8e9d8fff com.apple.CloudDocs (1.0 - 383.13) <5FD9138D-09D9-3B97-BBAD-5692E1687F30> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff8e9fb000 - 0x7fff8ea1aff7 com.apple.contacts.vCard (1.0 - 2137.1) <41529BD9-1BCC-3A62-92BA-2A7110867355> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
0x7fff8eb3f000 - 0x7fff8eb44fff com.apple.TCC (1.0 - 1) <F5EEB2D3-9517-3975-97BE-22CB8E11B8A3> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff8ec0d000 - 0x7fff8ec7cfff com.apple.datadetectorscore (7.0 - 460) <E8616F01-90AC-3863-B18C-426E6DD1ACDE> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff8ec7d000 - 0x7fff8ec80ff7 com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <6932B5EC-0EA9-333D-BF7E-665047392FEC> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff8ecf2000 - 0x7fff8ed29ff7 com.apple.LDAPFramework (2.4.28 - 194.5) <9AE33BF2-FB17-342D-8F1E-5F83C6E6EB69> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff8ed2a000 - 0x7fff8ed91fff com.apple.framework.CoreWiFi (11.0 - 1101.20) <993592F1-B3F1-3FAD-87BD-EA83C361BCCF> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff8ed99000 - 0x7fff8f234ffb com.apple.GeoServices (1.0 - 1151.49.1) <2D887517-B73D-30FF-91DC-AF6AD91F96B9> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fff8f235000 - 0x7fff8f6abfff com.apple.CoreFoundation (6.9 - 1258.1) <943A1383-DA6A-3DC0-ABCD-D9AEB3D0D34D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff8f6ac000 - 0x7fff8f6acfff com.apple.Carbon (154 - 157) <8F6ED602-5943-3E29-A793-BC331E2C183D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff8f6ad000 - 0x7fff8fa20fff com.apple.FinderKit (1.4.4 - 1.4.4) <76E52C7F-CA82-337E-BF8E-9961F11C4B8D> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
0x7fff8fa21000 - 0x7fff8fa2aff7 libsystem_pthread.dylib (138.10.4) <3DD1EF4C-1D1B-3ABF-8CC6-B3B1CEEE9559> /usr/lib/system/libsystem_pthread.dylib
0x7fff8fde0000 - 0x7fff8fe6ffff com.apple.CorePDF (4.0 - 4) <849BBFF6-0700-3ED1-98DF-A6E93B9B707F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff8fe70000 - 0x7fff8fea0ff3 com.apple.CoreAVCHD (5.8.0 - 5800.4.2) <4AAFB1C4-3708-30F9-ACFA-90564347204C> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff8fec6000 - 0x7fff8ff0cff7 libauto.dylib (186) <999E610F-41FC-32A3-ADCA-5EC049B65DFB> /usr/lib/libauto.dylib
0x7fff8ff18000 - 0x7fff8ff20fef libcldcpuengine.dylib (2.7.3) <385BE8CE-16D8-3FCB-8558-8EB744D3DFE6> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff8ff21000 - 0x7fff8ff26fff com.apple.DiskArbitration (2.7 - 2.7) <F55902AA-5316-3255-A701-FDED5B553065> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff8ff27000 - 0x7fff90019ff7 libiconv.2.dylib (44) <F05A0A5A-92A9-3668-8F20-F27CBDA26BE9> /usr/lib/libiconv.2.dylib
0x7fff9001a000 - 0x7fff9001efff libcache.dylib (75) <9548AAE9-2AB7-3525-9ECE-A2A7C4688447> /usr/lib/system/libcache.dylib
0x7fff90904000 - 0x7fff90b50ff7 com.apple.AddressBook.framework (9.0 - 1679.10) <24F823D3-C3FC-3AF9-B8B3-C166539DBD11> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x7fff90b51000 - 0x7fff90b52fff libDiagnosticMessagesClient.dylib (100) <4243B6B4-21E9-355B-9C5A-95A216233B96> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff90b53000 - 0x7fff90bb1fff com.apple.CoreServices.OSServices (728.13 - 728.13) <27C12B92-7845-38DD-B82D-DC5B678352D6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff90bb2000 - 0x7fff90f06fff com.apple.Foundation (6.9 - 1259) <71A9D3A0-0B1F-3E3A-86F3-1486365A6EF2> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff90f21000 - 0x7fff90f4aff7 libxslt.1.dylib (14.4) <72CD1CA4-1FBD-3672-ADCE-A89AB741689A> /usr/lib/libxslt.1.dylib
0x7fff90f4b000 - 0x7fff90f4dfff com.apple.CoreDuetDebugLogging (1.0 - 1) <7C932160-AC9C-3173-900F-98138E829CB3> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
0x7fff90fea000 - 0x7fff9150cfff com.apple.QuartzComposer (5.1 - 334) <80235264-CA1B-3E3F-96F7-5F6F52FDC5B6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff9150d000 - 0x7fff9151bff7 libbz2.1.0.dylib (38) <28E54258-C0FE-38D4-AB76-1734CACCB344> /usr/lib/libbz2.1.0.dylib
0x7fff9151e000 - 0x7fff9154cff7 com.apple.CoreServicesInternal (248.2 - 248.2) <6E111F0A-D7F1-3738-ADE7-CF983BD4EC8B> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff915b4000 - 0x7fff915bafff com.apple.IOAccelerator (205.11 - 205.11) <C51BF724-F8E8-3B9F-806E-A00C65056445> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff9163a000 - 0x7fff91720ff7 libcrypto.0.9.8.dylib (59.60.1) <D68067AD-D1E0-3196-9796-51BE9B969C8E> /usr/lib/libcrypto.0.9.8.dylib
0x7fff91734000 - 0x7fff917a8ff7 com.apple.Heimdal (4.0 - 2.0) <5D365381-8B5E-3259-8867-FC4A7D307BDE> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff91ae8000 - 0x7fff91b5ffeb libcorecrypto.dylib (335.50.1) <B5C05FD7-A540-345A-87BF-8E41848A3C17> /usr/lib/system/libcorecrypto.dylib
0x7fff91bcb000 - 0x7fff91be4fff com.apple.CFOpenDirectory (10.11 - 194) <11F95672-55E0-3F9D-9171-5E8C56AEE948> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff91c8c000 - 0x7fff91e55ff7 com.apple.ImageIO.framework (3.3.0 - 1459) <72B4D556-2600-3CA0-89F1-6BA24A4274B3> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff91e56000 - 0x7fff91eebfff com.apple.ink.framework (10.9 - 214) <1F76CF36-3F79-36B8-BC37-C540AF34B338> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff91eec000 - 0x7fff91f8cfff com.apple.Metadata (10.7.0 - 972.34) <A58195C5-5D5C-32D5-8BBB-F4D32201E5AA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff9209e000 - 0x7fff920d8ff7 com.apple.DebugSymbols (132 - 132) <23A42C53-B941-3871-9EE2-4C87A46005B5> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff920e9000 - 0x7fff920ebfff com.apple.SecCodeWrapper (4.0 - 261.40.2) <1F832591-59A8-3B3F-943F-D6D827463782> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff920ef000 - 0x7fff92129fff com.apple.QD (3.12 - 302) <0FE53180-2895-3D14-A1E7-F82DE1D106E1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff92149000 - 0x7fff9218eff7 com.apple.coreservices.SharedFileList (24.4 - 24.5) <1D2AD77B-778F-3253-A295-3D0A32A8121C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff9220a000 - 0x7fff92415fff libFosl_dynamic.dylib (16.24) <5F9DB82D-FD4B-3952-8531-CE020F93ED49> /usr/lib/libFosl_dynamic.dylib
0x7fff9241e000 - 0x7fff9242aff7 com.apple.OpenDirectory (10.11 - 194) <31A67AD5-5CC2-350A-96D7-821DF4BC4196> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff92432000 - 0x7fff9244fff7 com.apple.AppleVPAFramework (2.1.2 - 2.1.2) <41378C0B-B56A-3A73-9BD0-E06FA1F87B8C> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
0x7fff9245d000 - 0x7fff92474ff7 libsystem_asl.dylib (323.50.1) <41F8E11F-1BD0-3F1D-BA3A-AA1577ED98A9> /usr/lib/system/libsystem_asl.dylib
0x7fff92475000 - 0x7fff92477fff com.apple.loginsupport (1.0 - 1) <9B2F5F9B-ED38-313F-B798-D2B667BCD6B5> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff92478000 - 0x7fff92480fff com.apple.NetFS (6.0 - 4.0) <842A5346-24C3-3F22-9ECF-E586A10EA1F2> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff924af000 - 0x7fff924affff com.apple.Accelerate (1.10 - Accelerate 1.10) <5831771A-C1C3-3625-9FE9-2CCB6B2E7EE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff924e3000 - 0x7fff924e4ffb libSystem.B.dylib (1226.10.1) <012548CD-614D-3AF0-B3B1-676F427D2CD6> /usr/lib/libSystem.B.dylib
0x7fff92552000 - 0x7fff9275ffff libicucore.A.dylib (551.51.4) <3899B146-3840-3D4A-8C4A-FE391D5D25C7> /usr/lib/libicucore.A.dylib
0x7fff92894000 - 0x7fff9289bff7 libcompiler_rt.dylib (62) <A13ECF69-F59F-38AE-8609-7B731450FBCD> /usr/lib/system/libcompiler_rt.dylib
0x7fff9289c000 - 0x7fff9289cfff libenergytrace.dylib (10.40.1) <0A491CA7-3451-3FD5-999A-58AB4362682B> /usr/lib/libenergytrace.dylib
0x7fff92995000 - 0x7fff92a0afff com.apple.framework.IOKit (2.0.2 - 1179.50.2) <A509D3AE-9D48-31B7-89C7-326A7A2007B2> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff92a1a000 - 0x7fff92aa7dd7 com.apple.AppleJPEG (1.0 - 1) <BF7EDBDB-A52D-37F7-BDE4-EAD49310D7A9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff92ab4000 - 0x7fff92b8affb com.apple.DiskImagesFramework (10.11.4 - 417.4) <B9525D22-6F0D-39C5-BA9B-9DF195FE1968> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff92b8b000 - 0x7fff92b8cffb libremovefile.dylib (41) <552EF39E-14D7-363E-9059-4565AC2F894E> /usr/lib/system/libremovefile.dylib
0x7fff92b8d000 - 0x7fff92b8efff libsystem_secinit.dylib (20) <32B1A8C6-DC84-3F4F-B8CE-9A52B47C3E6B> /usr/lib/system/libsystem_secinit.dylib
0x7fff92c07000 - 0x7fff92c36fff com.apple.securityinterface (10.0 - 55065.40.1) <1BB39B19-DD74-347E-A344-0E6781773577> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fff92c37000 - 0x7fff92c45fff libxar.1.dylib (302) <03207F66-2C4A-3DBD-8D81-70F4C85903C4> /usr/lib/libxar.1.dylib
0x7fff92c52000 - 0x7fff92c5afff com.apple.CoreServices.FSEvents (1223.10.1 - 1223.10.1) <7F5B7A23-BC1D-3FA9-A9B8-D534F1E1979A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff93475000 - 0x7fff934d8fff libAVFAudio.dylib (161.2) <1A98DBF3-490B-37FB-928A-AB1E36E6E5DD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
0x7fff93600000 - 0x7fff9367dff7 com.apple.iLifeMediaBrowser (2.10.1 - 721) <C7081359-4300-3D44-A8AE-143D6E5ED153> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowser
0x7fff936d0000 - 0x7fff936d8fff libGFXShared.dylib (12.1) <5A0C2493-200C-30BE-97D5-8E8C0B8E604D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff936d9000 - 0x7fff936f5fff com.apple.GenerationalStorage (2.0 - 239.1) <8C821448-4294-3736-9CEF-467C93785CB9> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff937b1000 - 0x7fff937c7fff com.apple.CoreMediaAuthoring (2.2 - 953) <5103EF2E-BB0A-302B-B8BB-CED301BC746B> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fff937c8000 - 0x7fff937ccfff libGIF.dylib (1459) <58F85C45-96D2-3713-A8C0-B2579B419A80> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff937cd000 - 0x7fff93819ffb com.apple.HIServices (1.22 - 550) <6B76B41C-CF5A-34C4-89F4-EFD7CA3D1C9D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff9381a000 - 0x7fff938c5fff com.apple.PDFKit (3.1 - 3.1) <27AF3C85-1C0B-389C-856C-2E527620C195> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff938c6000 - 0x7fff93914fff libcurl.4.dylib (90) <12E01E4B-24C9-394C-9D2C-85CF85D5F459> /usr/lib/libcurl.4.dylib
0x7fff93947000 - 0x7fff93950ff3 libsystem_notify.dylib (150.40.1) <D48BDE34-0F7E-34CA-A0FF-C578E39987CC> /usr/lib/system/libsystem_notify.dylib
0x7fff93951000 - 0x7fff9399cff7 com.apple.CoreMediaIO (703.0 - 4791) <9E77E5F7-BEF5-3D8F-B810-A21AED722F6B> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff9399d000 - 0x7fff9399fff7 libquarantine.dylib (80) <0F4169F0-0C84-3A25-B3AE-E47B3586D908> /usr/lib/system/libquarantine.dylib
0x7fff939a0000 - 0x7fff939bcff7 libsystem_malloc.dylib (67.40.1) <5748E8B2-F81C-34C6-8B13-456213127678> /usr/lib/system/libsystem_malloc.dylib
0x7fff93a8b000 - 0x7fff93a8ffff com.apple.LoginUICore (3.2 - 3.2) <5524E4BC-4700-39F4-AF06-E53322712EE0> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x7fff93b34000 - 0x7fff93b51ff7 com.apple.pluginkit.framework (1.0 - 1) <0BA96479-0451-3DA9-A2AC-FE1D86D383AB> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
0x7fff93b52000 - 0x7fff93c41ff7 libxml2.2.dylib (29.10) <B3B03292-7E1A-34AB-888C-3D49D63D60C6> /usr/lib/libxml2.2.dylib
0x7fff93c42000 - 0x7fff93c43ff3 com.apple.print.framework.Print (10.0 - 266) <3E85F70C-D7D4-34E1-B88A-C1F503F99CDA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff93c70000 - 0x7fff93cc1ff7 libcups.2.dylib (435.2) <91584A40-214D-33E8-A613-CE22289037C8> /usr/lib/libcups.2.dylib
0x7fff93cc2000 - 0x7fff93cc6fff libpam.2.dylib (20) <CFCD19BD-87BC-3F2B-BB1C-4C23E8E55F1A> /usr/lib/libpam.2.dylib
0x7fff93cc7000 - 0x7fff93cf6ffb libsystem_m.dylib (3105) <08E1A4B2-6448-3DFE-A58C-ACC7335BE7E4> /usr/lib/system/libsystem_m.dylib
0x7fff93cf7000 - 0x7fff93cfcff7 libmacho.dylib (875.1) <318264FA-58F1-39D8-8285-1F6254EE410E> /usr/lib/system/libmacho.dylib
0x7fff93cfd000 - 0x7fff93d31ff7 com.apple.CoreVideo (1.8 - 191.3) <1AA24A1B-CB84-3F6B-B6DE-11494542649C> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff93e18000 - 0x7fff93f45ff3 com.apple.CoreText (352.0 - 494.12) <ADBE8355-D4F5-3316-A6C4-D641D615CEC4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff940de000 - 0x7fff940dffff com.apple.TrustEvaluationAgent (2.0 - 25) <0239494E-FEFE-39BC-9FC7-E251BA5128F1> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff940e0000 - 0x7fff95346ff3 com.apple.CoreGraphics (1.600.0 - 960.3) <A2DA51BA-7A97-33B9-97A1-979F6401989C> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff955a0000 - 0x7fff955a3ffb libdyld.dylib (360.22) <25D28225-99AE-3A04-B98C-ACFF47D6D9B0> /usr/lib/system/libdyld.dylib
0x7fff955f5000 - 0x7fff955f7ff7 com.apple.xpc.ServiceManagement (1.0 - 1) <D96D7A6D-EDEB-35EE-B5D9-E33A3BF011B5> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff955f8000 - 0x7fff95609ff7 libsystem_trace.dylib (201.10.3) <E9311C03-9E61-3B13-AF3F-A64956FFF269> /usr/lib/system/libsystem_trace.dylib
0x7fff9560a000 - 0x7fff95727fff libsqlite3.dylib (216.4) <DC3D59E7-91A3-374F-957C-6699729CD82B> /usr/lib/libsqlite3.dylib
0x7fff9575b000 - 0x7fff9578cff7 libtidy.A.dylib (15.17) <6859415D-7A43-384E-ABDD-AA6B2AA9FDCD> /usr/lib/libtidy.A.dylib
0x7fff9578d000 - 0x7fff9579ffff libsasl2.2.dylib (209) <11C7D200-0CA5-30F4-A19A-178CA81D48FE> /usr/lib/libsasl2.2.dylib
0x7fff95a68000 - 0x7fff95d4dffb com.apple.CoreServices.CarbonCore (1136.2 - 1136.2) <2DBAFC9A-6CD6-351D-B1F4-87D81AA6D640> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff95d4e000 - 0x7fff95d56fff com.apple.frameworks.CoreDaemon (1.3 - 1.3) <CC53DC12-9231-3C4F-921B-9A770D463323> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff95da2000 - 0x7fff95e2bff7 com.apple.PerformanceAnalysis (1.0 - 1) <9EF745B2-ECD5-33F8-912F-E96771C9E6F8> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff95e2c000 - 0x7fff95e7aff7 libstdc++.6.dylib (104.1) <76E2AFB1-07E5-3F19-B692-F6E21B7E470D> /usr/lib/libstdc++.6.dylib
0x7fff95ed0000 - 0x7fff95ee0fff libSparseBLAS.dylib (1162.2) <6F591A0F-80D0-384D-8304-B035C4ED1BBD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff95ee1000 - 0x7fff95efdff3 libresolv.9.dylib (60) <A650B5C8-1950-36A0-86D1-0B2465318BFA> /usr/lib/libresolv.9.dylib
0x7fff95f0a000 - 0x7fff95ff0fef unorm8_bgra.dylib (2.7.3) <B315AE9C-9E09-3D9F-9513-EC2195908516> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
0x7fff96025000 - 0x7fff9603afff com.apple.ToneKit (1.0 - 1) <6D5AD263-308F-3F70-8D86-7027569D2694> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
0x7fff96048000 - 0x7fff960f8fff com.apple.backup.framework (1.7.4 - 1.7.4) <F304E9D1-991A-379E-9659-BF85C35B4808> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff96104000 - 0x7fff9610ffff libkxld.dylib (3248.60.11) <9F422A08-0212-36E1-BFF8-1491C70EBFCA> /usr/lib/system/libkxld.dylib
0x7fff9628e000 - 0x7fff96609ffb com.apple.VideoToolbox (1.0 - 1731.15.206) <19DD020F-128A-32B0-96A4-A51F111B549F> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff9660a000 - 0x7fff96788fff com.apple.UIFoundation (1.0 - 436.1) <AABB5267-E7B7-3D75-B051-E665BDA8DEF4> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff96789000 - 0x7fff968cefff com.apple.QTKit (7.7.3 - 2943.12) <79EA2D04-09EC-3266-A5F7-A4AACA97FE1E> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff96988000 - 0x7fff96b56ff3 com.apple.QuartzCore (1.11 - 410.14) <076BDE58-8AED-3D47-84FD-548CF8E8EDB9> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff96ca5000 - 0x7fff96f3bfff libmecabra.dylib (696.5) <EF6C0BD4-5FE8-34FB-8ADF-69A53CEC97A9> /usr/lib/libmecabra.dylib
0x7fff96f3c000 - 0x7fff96f53fff libmarisa.dylib (4) <E4919B03-D9BD-3AF8-B436-C415C98E3F0A> /usr/lib/libmarisa.dylib
0x7fff96f54000 - 0x7fff97046ff7 libJP2.dylib (1459) <90B4DD14-4D0B-3373-B1B6-DC8F53D78565> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff9705b000 - 0x7fff970abff7 com.apple.Symbolication (1.4 - 58044) <F70BF765-FBE9-3F1E-85CA-BB2F8E53E8C2> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff970ac000 - 0x7fff970b4fff libsystem_networkextension.dylib (385.40.36) <66095DC7-6539-38F2-95EE-458F15F6D014> /usr/lib/system/libsystem_networkextension.dylib
0x7fff970b7000 - 0x7fff970bafff com.apple.Mangrove (1.0 - 1) <2D86B3AD-64C3-3BB4-BC66-1CFD0C90E844> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff970bb000 - 0x7fff970c7fff com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <6BA06290-D4A3-351C-87F9-B61EF61FF055> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff970ff000 - 0x7fff9713dff7 libGLImage.dylib (12.1) <BB1F1A93-5101-3906-AB17-8D83FCB200F9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff9713e000 - 0x7fff971cdff7 libCoreStorage.dylib (517.50.1) <E6283FE9-B5AC-3110-8D4C-8E2BF185983E> /usr/lib/libCoreStorage.dylib
0x7fff97272000 - 0x7fff97278fff com.apple.XPCService (2.0 - 1) <5E2122D6-FFA2-3552-BF16-9FD3F36B40DB> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0x7fff97492000 - 0x7fff97719fff com.apple.CFNetwork (760.6.3 - 760.6.3) <8CB9CB2E-D0FB-31D4-A1AE-2A5FE028AD6B> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff9771a000 - 0x7fff9775bff7 libGLU.dylib (12.1) <CD7A5916-3E3C-3EF3-A275-B281016B99CB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff97d3f000 - 0x7fff97d4dfff com.apple.ToneLibrary (1.0 - 1) <AF05AF34-9BC4-3BA6-81C1-7420F22C9D7D> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
0x7fff97d4e000 - 0x7fff97d70ff7 com.apple.Sharing (442.13.6 - 442.13.6) <DDD2811C-6ECB-32F2-8EE1-69BF9657B4A8> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff97d71000 - 0x7fff97d9efff libdispatch.dylib (501.40.12) <C7499857-61A5-3D7D-A5EA-65DCC8C3DF92> /usr/lib/system/libdispatch.dylib
0x7fff97d9f000 - 0x7fff97deeff7 com.apple.opencl (2.7.0 - 2.7.0) <39581F1A-04FE-3CCA-9118-E9BB9053F7A1> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff985f9000 - 0x7fff9869dfff com.apple.Bluetooth (4.4.6 - 4.4.6f1) <F8E54D34-DAAB-319F-8AE7-F3C55CA0CC68> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 6
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 9962
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=439.9M resident=0K(0%) swapped_out_or_unallocated=439.9M(100%)
Writable regions: Total=3.3G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=3.3G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate.framework 256K 3
Activity Tracing 2048K 2
CG backing stores 2872K 4
CG image 368K 55
CG shared images 272K 9
CoreAnimation 428K 80
CoreUI image data 2156K 26
CoreUI image file 192K 4
Dispatch continuations 4096K 2
Foundation 4K 2
Image IO 8K 3
JS JIT generated code 256.0M 3
JS JIT generated code (reserved) 2.8G 3 reserved VM address space (unallocated)
JS VM register file 8320K 3
JS garbage collector 272K 3
Kernel Alloc Once 8K 3
MALLOC 216.1M 53
MALLOC guard page 32K 7
Memory Tag 242 12K 2
Memory Tag 251 24K 3
OpenCL 24K 4
Process Corpse Info 2048K 2
STACK GUARD 56.1M 27
Stack 26.8M 27
VM_ALLOCATE 148K 14
VM_ALLOCATE (reserved) 1032K 4 reserved VM address space (unallocated)
WebKit Malloc 5508K 7
__DATA 41.7M 378
__IMAGE 528K 2
__LINKEDIT 126.1M 87
__TEXT 313.8M 362
__UNICODE 552K 2
mapped file 124.8M 75
shared memory 16.3M 11
TOTAL 3.9G 1238
TOTAL, minus reserved VM space 1.2G 1238
Model: MacBookPro5,5, BootROM MBP55.00AC.B03, 2 processors, Intel Core 2 Duo, 2.26 GHz, 8 GB, SMC 1.47f2
Graphics: NVIDIA GeForce 9400M, NVIDIA GeForce 9400M, PCI, 256 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1067 MHz, 0x0198, 0x393930353432382D3032302E4130304C4620
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1067 MHz, 0x0198, 0x393930353432382D3032302E4130304C4620
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.106.98.100.24)
Bluetooth: Version 4.4.6f1 17910, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: ST9160314ASG, 160.04 GB
Serial ATA Device: MATSHITADVD-R UJ-868
USB Device: USB 2.0 Bus
USB Device: Card Reader
USB Device: Built-in iSight
USB Device: USB Bus
USB Device: BRCM2046 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB Bus
USB Device: Apple Internal Keyboard / Trackpad
USB Device: IR Receiver
USB Device: Fitbit Base Station
Thunderbolt Bus:
Dear Charlie,
When you receive the message about the available RAM, are you also running other applications that can be RAM demanding?
Also, regarding the crash you are facing during the step 2, can you please send us the Quality Report and the log file to further investigate? You can send the files to support@pix4d.com.
Is there the new Pix4DMapper Pro ver. 3.0 for OS X? There is a link for download?
Hello Antonio,
The 3.0 was officially released for Windows yesterday. The OS X version will follow shortly.
We will inform you in this post when 3.0 OS X is released.
Hello, is the new version for Mac out?
I cannot run the OS X trial of Pix4D.  I am on an iMac running OS X 10.11.6.
When I open Pix4D, I accept the terms, then after the login window on the “welcome” window I choose the Pix4Dmapper Pro trial and click OK.
I immediately see the message:
Error: This is an old version of the software. Please download the latest version here https://cloud.pix4d.com/download/
The link takes me to the Windows download page, which I don’t need.
But if I just hit the OK button, I remain on this “Welcome” window with the same message.
I tried OS X versions 2.25 and 1.61, the same message is shown on both.
Please let me know how to ignore the message and use the software trial.
@Eduardo: The 3.0 OS X version is released and you can find more information here.
@Janvier: There was an issue with the trial licenses in version 2.2 that should be fixed with version 3.0.
This post refers to OS X Pix4Dmapper 2.2. Since the release of OS X Pix4Dmapper 3.0_, we have created a new post here, on which you can post your comments and your feedback._
This post will be closed to comments.
We hope version 3.0 will better meet your needs.
