Autel EVO IIV3 Processing errors
Autel EVO II V3 RTK — Pix4D Mapper Processing Issues
Hi
I’m trying to process an Autel EVO II V3 RTK for photogrammetry and running into multiple errors when processing the data in Pix4D Mapper. We normally use senseFly eBee drones for our surveys, and wanted to compare results, but the EVO II data won’t process.
Symptoms I’m seeing:
  • In Map view the points are being placed in the wrong state.
    • I am not getting the post mission with the image and all the green dots.
  • The Initial Processing, Point Cloud, and Mesh steps fail.
  • Errors include Generating tiles failed and Dense Processing failed (among others).
I’ve tried pulling the imagery both from the SD card and directly from the drone, but I can’t find any clear guidance on the correct workflow or settings for processing data from the Autel EVO II V3 RTK.
Any help or recommended steps would be greatly appreciated.
Hi James,
Apologies for the delay. It sounds like you have a lot going on with this project. First, if the points or images are not being placed correctly on the map, then likely your coordinate system is not set correctly. When you bring in your GCPs, you need to set the coordinate system and the order of the coordinates. Are the coordinates X, Y, and Z? Or are they Y, X, and Z?
As for the processing failure, we will need your .log files. This will tell us what is causing processing to fail. Feel free to attach them to this posting.
