Hi all. Trying to merge data sets but ground control will not pull smaller model into larger area. Any idea please
Would you please make sure that xyz values of the GCPs/MTPs that were used to match the projects are the same?
Kind regards,
Hi Yuka,
The GCPs were captured with high accuracy GPS. The smaller area was captured at a later date and the four GCP’s in question were shot in at that later time. What is confusing is that other small areas I want to blend/merge have done so exactly as expected as you can see on the right of the screen shot.
Very best,
James.
Would you please go to the link below to see if there are any steps that you could have missed? There is a video that may be helpful as well.
Kind regards,
Thank you Yuka,
