Just bought a Phantom 4 Pro+, with integrated display.
Not able to install Pix4D capture on the device. I tried to connect (USB) an external Android device with Pix4D capture installed, but failed to connect.
Is Phantom 4 Pro+ not compatible with Pix4D capture?
Steph
Hi Stéphanie,
Phantom 4 Pro+ is not supported on Android and iOS Pix4Dcapture. This drone comes with a special remote controller that has an integrated screen. We do not know if we will be able to support it or not. Actually it is not supported at the moment because the DJI controller is for now a closed system that cannot work with third-party apps.
Do you have any news about this topic please?
thank you.
David
As far as I know, the integrated display of the Phantom 4 Pro+ still can’t run third party apps. You also can’t connect an external Android or iOS device on the remote controller.
I bought the normal remote controller of the Phantom 4 Pro (without integrated display). I can now run Pix4D Capture on an external Android device.
Regards
Stéphane
