Hi
I just updated from 4.6 to 4.9 and the most annoying thing is happening. When i add a folder of pictures I have to locate it then when I hit add to add more it does not open in the same folder it goes back to a default Pix 4d folder and I have to navigate each time to the folder containing the pictures. It has turned a 30 second job into a 5 minute one. I have also noticed I can no longer add multiple folders by using shift or ctrl and I now have to add each folder seperatly then navigate back to the folder to add the next one. Surly this isnt how it works now. If this is the case how can I revert back to 4.6 because doing a project with 15k pics is painful to load
Welcome to the Pix4D Community!
I know this is not ideal, but you can copy the path and the “paste” is in the new window when selecting a new folder.
However, a better solution could be the following:
- click on the
Add Images...button
- navigate to the root directory containing all the subdirectories with the images
- in the top-right corner, type
*.jpgin the search field
- all .jpg files in all the subfolders are now showed
- press
Ctrl + ato select all images - click
Open
This will add the images from different folders to PIX4Dmapper with just one step.
We always suggest to keep using the latest version of PIX4Dmapper. However, you can still find previous PIX4Dmapper versions here:
Daniele
