I created a project in the cloud based on an existing data set, i.e. Orthomosaic, DSM, Point Cloud, and Mesh OBJ. I would like add photos to the project to be able to use the inspect functionality. Is there anyway to add photos after the fact?
Thanks for your time.
Chris H
Hi Chris,
You can only upload output results to the cloud project. Adding images to that project is not possible.
If you want to use the virtual inspector tool, you have to process the project on the cloud. For more information, I would suggest you to go through our support page on How to access and use the Virtual Inspector.
