I noticed a common issue with lack of refresh o fthe map view when tabs are resized in PIX4DMapper. This often leadds to lack of alignment among the Google map, camera positions and bounding boxes. It is quite annoying and currently the only solution is to zoon in/out the map view to force a map view refresh. Example: try moving a separation between the “Processing” or “Log output” and the map in the “Map View” tab.
@artur.krukowski I noticed the same recently and as you mention, for the moment, you need to zoom in/out for the map information to align with the satellite image. Cheers
