So I was wondering that if I was to use the mobile app Pix4Dcapture to capture the photos before rendering in the cloud application, I know I can use a Bebop 2 drone, but is the Bebop 2 power drone also usable with this. If so do I just set it as Bebop 2? Thx
Hello @rex,
It is not clear what you are referring. Pix4Dcapture only supports the drones listed in the support article on Supported drones, cameras and controllers.
If the Pix4Dcapture app does not support your drone at this time, you can use any other image acquisition software and still process the data using Pix4Dmapper. Pix4D’s software is drone/app agnostic, meaning that you will be able to process image data obtained from different image acquisition app or the drone. For more information see which image acquisition app can I use with Pix4D’s software?
