I had the idea to add a “Z-axis offset” feature to the point cloud.
Why is this needed?
It often happens that cameras maintain their internal camera orientation reasonably well, and the users of these cameras are “very familiar” with them. Projects from these cameras produce a very repeatable XY error (around 1 GSD / 1.5–3 cm) and a constant Z-axis offset. The project preserves the correct relative heights, which can only be shifted by a constant value—this also helps maintain a low error along the Z-axis (absolute height relative to the coordinate system).
I am aware that this is not correct according to the theory and science of photogrammetry, and that it is always best to use Ground Control Points and Check Points, but sometimes this saves the day when time is of the essence.
Adding one GCP sometimes does the trick, but sometimes Pix4D “can’t quite get” the project to align to a single point along the Z-axis. Even changing the accuracy of the external camera orientation doesn’t solve the problem.
Of course, you can read the Z value of the point, export the point cloud to Cloud Compare, and reimport it, but it’s better to do it all within a single software program.
Of course, I’m aware that measuring points on the images afterward can cause errors, so after such an operation, marking points on the images should be disabled (unless the Z values of the images also change)?
