Hello
I use phantom 4 v2 with Pix4 D
After loading the mission Phantom 4 v2 takes off and stops at the beginning of the mission and does not perform it, what is the problem and what is the solution
Hi Yair,
In some cases the drone stops at the beginning of the mission because it’s sensors are not optimally set up.
We recommend to check that the drone’s systems are properly functioning and calibrated. For example, many times the drone will stop if the compass is not calibrated.
Hope this helps,
