I have to survey a terrain, with different elevations (the maximum difference in altitude is ablout 100 m). I will be flying an UAV at 150 m and another at altitude of 200 m. Which kind of practice should I follow and what points should I consider while surveying ? Is their any role of GCPs ? (All the elevations are from same reference level.)
If you have the ability to take some GCP’s, that would make things a lot easier for you.
I flew a 2 km square project from a couple different elevations, when i merged the projects it was a complete jumbled mess. I added my GCP’s and that helped a bit, but the true magic came from adding MTP’s
Once those were added it was perfect.
