Hello, I have put the images of the calibration panel and for the first time I see those warnings.
What is it about?
Eddison
What is it about?
Eddison
The warnings mean that there is a problem with the information in the exifs of those images, and we cannot safely apply another fix.
In either case, you can try doing the following:
Click Calibrate…add the images of the radiometric calibration target and the albedo values and click OK. This can be done for each band of the camera. Once all bands are calibrated, it should be possible to generate the Reflectance Map.
If there is an issue remaining after this process, please send us the Quality Report and Log file of your project. The Quality Report can be created in Process > Generate Quality Report and the Log file is the text file in the results folder.
Please do not hesitate to contact us if you need further assistance.
Hola, muchas gracias, Eddison
