CAN ONLY DJI PHANTOM 4 PRO DRONE BE USED TO CAPTURE ACCURATE VOLUME OF STOCK PILE.?
IS THERE ANY HARDWARE REQUIRED?
PLZ REPLY.
PLZ REPLY.
Yes you can just use the drone. GCP´s are needed for higher accuracy. I’ve done same project using GCP´s and without them and had only minor differences.
If you are covering large area then I suggest you to use GCPs
And always remember to check your quality report
ok thanks. also in the output we get e.g. in the results contains VOLUME = 128 +/- 8 means VOLUME = 128+8 OR 128-8 OR WHAT IS THE CORRECT.
HI Mahesh,
Pix4D software is hardware agnostic, so you can use imagery from virtually any digital camera. The Phantom 4 Pro UAV is a very popular UAV due to the large 1" 20MP Global Shutter sensor.
I would refer you to the Support article “Error estimation in Volume calculation” & How Pix4Dmapper calculates the Volume? for a more in depth explanation of the the values the Pix4D reports.
Best Wishes,
Aaron Woods
