Volume computation between 2 surfaces
Right now I generate 2 DSM surfaces an then use a GIS to compute the volume changes in the desired area. Is it possible to compute the volume between two surfaces directly in pix4D?
Best regards
At the moment, you cannot analyze the spatial-temporal variation of the volume of an area inside the same Pix4Dmapper project. In order to perform a comparison between two or more volumes in the same area, you need to create two or more projects.
If you are interested and have some basic programming skills, you could create a code using our Pix4Dengine functions provided by the SDK. This will definitely help automatize the workflow and compute more volumes at once. Please contact the technical sales for more details about trying and purchasing Pix4Dengine.
Teodora
