utilisation nuage de points et mesh
Bonjour,
je n’arrive pas à utiliser mon modèle texturé sur Archicad. Y’a t’il une procédure afin de bénéficier du rendu 3D texturé du modèle produit sous Pix4DMapper? Est ce que Revit permettrait de travailler directement sur le mesh? ou le nuage de points?
merci de vos retours.
A.Perier
Bonjour et bienvenu à la Communité de Pix4D,
je n’ai plus un bon niveaux de français, donc je doit utilizer l’Anglais.
When you export the Point Cloud and the Mesh, you have several options; I understand that ArchiCad allows you to Import .xyz and .e57 Point Clouds, but only as reference for your work, and not in order to show it in the plans and renders: Working with Point Clouds | User Guide Chapter | Graphisoft Help Center.
About the 3D Mesh, Pix4DMapper doesn’t export a format that you can use in ArchiCad: Model/3D Formats Opened by ArchiCAD.
I work mostly with Revit and Recap, beides Pix4DMapper, and I noticed that there is just one improvement than ArchiCad: I can print the Point Cloud in my plans. If I want to use a Point Cloud, first I need to Create a New Project in ReCap, Import the .las Point Cloud from Pix4DMapper, and then Save As .rcp; finally, I can Import the .rcp in Revit. I never used the 3D Mesh in Revit, however I understand that you need a plug-in to do so.
I hope that you will receive an answer in French as soon as possibile,
Best Regards,
Giancarlo
