Good Morning,
I am using a Case Rowtrac 400 with a pull behind Flexicoil 67XLT with the Trimble TMX 2050 and Trimble Field IQ node on the sprayer. I talked with some other people yesterday and apparently I need to export a map that shows that the whole field has been sprayed except for the areas that have weeds. In essence I need to export a prescription that is a reverse magic tool that highlights everything that doesn’t need to be sprayed as already sprayed and leaves the detected weeds as areas that haven’t been sprayed. Then as the sprayer travels over those areas they get recognized as areas that haven’t been sprayed yet and the spray computer turns on the necessary sections. Is it possible to export a map like that with your software and if so, what is the workflow to do that?
That will give me a map that has 2 rates, 0 gals per acre and 10 gals per acre (my target rate is 10 gals per acre). I need a map that has sprayed areas and un-sprayed areas, not different rates. Does that make sense?
No it won’t because you delete the first rate and then you have an inverted map.
Ok. I’ll give it a try.
In order to achieve this, the new Operation should have a specific column, specific folder names and imported as limits.
Please share the operation, and we will share a compatible format with you.
Good Morning and thanks for your help.
Here is my workflow for getting the map loaded onto my spray computer. I went wrong somewhere yesterday as the map that I pulled up on the sprayer was a solid prescription map and not a sprayed/ not sprayed map. Could you please help me get the correct settings to load the map on my Trimble TMX-2050.
Post Flight Processing
Transfer Images
Note number of pictures taken in qBase
Transfer images from sd card to documents/qbase/pictures/Flight #
Delete first two blurry images
After transfer of images delete the folder on sd card
Download Log Files
Insert battery in drone body and hook up usb cable to the top of the drone
Open qBase and select “transfer flight logs” under the tools tab
Download the PFC flight logs and note the file number for each flight to the worksheet
Find the flight logs in File manager-downloads and transfer to documents/qbase/logs/Flight #
Extract log files in file manager
Download PPK Data
Extract micro sd card from Ibase
Insert Micro sd into reader
Save #######.25R file to documents/qbase/PPK
One rinex file will work for all flights. File number resets when the power is disconnected
Note the file number for the corresponding flights on the worksheet
Geotag Files
Open qbase-tools-geotag
Load log file for corresponding flight # documents/qbase/logs/Flight #
Load images documents/qbase/pictures/Flight #
Make sure the first 2 blurry images are deleted. If the # of images doesn’t match the flight log you will get an error
Set export files to documents/qbase/postprocessed/Flight #
Load PPK/Rinex file ########.25R
Select CVS and O,P,K for pix4d
Select KML
Select Geotag
Click Ready
Click Start
Pix4d Fields
Open and name a new project with the total acres at the end of the name
Load geotagged images documents/qbase/postprocessed/Flight #
Select Fast Processing
Set slider to full resolution
Add any additional files for the project
Start Processing
Set the boundaries and save for future use
Use the same name as the project name
Use Boundary to trim
Select Magic tool Orthomosaic-Boundary
Cell Size = 5 ft
Adjust rotation to align with crop rows
Enter “Weeds on Wheat Fallow”
Select boxes with weeds as “Wanted” and bare fallow as “Not Wanted” on mosaic
Click “Clean up”
Click “Output Settings”
Select Operation and enter “Green on Brown + Field Name”
Click Learn on my data
Select “Gallons per Acre”
Select “Assign new rate to empty cells” and click fill now
Delete rate 1
Enter 10 Gallons per acre on new rate
Click Export
Select “Operations”
Select “Generic Tractor/Sprayer” on the drop down menu
Select “Shapefile”
Select “Ignore”
Export to USB under Folder AgGPS/Prescriptions
Should export three files for Timble .shp .shx .dbf
Other two files exported are not used by Trimble Spray Computer
Thank you for sharing this with us.
The On/Off prescription should be in the following folders:
"AgGPS\Data\Farmername\fieldname"
It should also have specific column names
Share the prescription with us so we share it with you.
Best
Ok. I’ll try it when we get home. On vacation right now for two days.
Good Evening,
I created the file AgGPS/data/Simpson/3 Quarters on my USB memory stick and saved my prescription map to that folder. I didn’t see that it made any difference as the only prescription map that I was able to load was the previous on that didn’t load properly. I have attached the prescription map that I am trying to load.
(Attachment Green on Brown 3 Quarters_Rx.cpg is missing)
(attachments)
Green on Brown 3 Quarters_Rx.dbf (600 Bytes)
Green on Brown 3 Quarters_Rx.shp (483 KB)
Green on Brown 3 Quarters_Rx.shx (116 Bytes)
I will send you an email to continue this discussion.
Hello group,
I have been trying to generate a weed map with the Trimble latest version 14.6. You only need 3 file in the AgData Prescriptions folder .dbf .shp .shx.
.cpg & .prg i havent sent to the controller.
The map still wont turn on for complex polygons as shown above in the chat. This test map worked as required because the 80L/Ha zone is all joining.
Any other suggestions or things i should try?
Could you share the file from this company?
Hello, nice to find some people trying to solve same problem as me.
Today we tried a weed prescription map as Rx and ive tried 2 types of prescription:
- Zones with no weed without zones (No polygons) and manually set on the GFX750 to apply 0 l/ha on no prescription zone.
- Creating zones (polygons) also on zones with no weed, and put 0 l/ha on rate of the attribute table.
In both cases when we entered the no applying zones, the objetive rate marked 0 l/ha (that should be the correct) but real rate showed not less than 15-20 l/ha and sections of the sprayer didnt turn off at all…
A company here in Argentina is making prescriptions for this cases, and they gave me the advice that the polygons might be “all joined” with lines or similar. Also that the right form to import it to the display is as a boundary, not as a Prescription (makes sense, as its not a variable rate application, its just a simple spray/not spray indication…).
The right way to put it on the external USB when plugging it to the display is:
AgGPS>Data>farmer name>field name>… i exported it like that from SMS, but its important to export it as a Boundary (its a shapefile + .pos file).
My problem (photo) that couldnt solve at all today, is that when i try to turn on the boundary it shows lots of boundarys (every polygon as one boundary) and you can only make active one boundary at a time…
Hi Francisco,
Thank you for posting here and sharing your experience. You are right this is not a prescription but a hack to the monitor, importing the areas without weeds as “no application”.
Point 2: If the sprayer did not turn off completely, it seems to be related to a misconfiguration of the implement.
May I ask if you have the VRA module unlocked? This will be easier.
I will reach out to your email so we can interact further.
