I am facing an issue where I can’t find the correct Taiwan coordinate projection system in the ‘Camera’ tab right after I imported the image. However, if I imported the control points in the ‘Tie points’ tab to the same project, I could find the correct projection.
The image projection that I use when I am scanning using Pix4dCatch is TWD97 - EPSG 3826
The image projection that I get after importing the image is TWD97 - EPSG 3824
The projection that I can select in the ‘Tie points’ is TWD97 - EPSG 3826
Thank you
