I am trying to process the data, which seems to have two different altitude values in flight (as Can be seen in the attached). When running the ortho of such a dataset, the fields look to overlap each other and are not correctly compensated.
Hello, I recommend to add 3 mtps in the common area between two flights or adding the GCPs on both of the flights.
