Is it okay to delete the files in the temp folder under the main project folder for Pix4Dmatic? I’d think they would clear after processing completes, but all my temp folders still have files, some of which are quite large.
The files inside the “temp” folder can be removed after you close the project. Some of them are used to increase the performance of PIX4Dmatic, they will be recreated when you open the project next time. Please note that removing files from the “temp” folder while the project is still open might result in crashes of PIX4Dmatic.
Kind regards,
Alexey
Thanks, this is helpful.
