Hi there, I have a spraying implement with a 20inch spray width and am curious what cell size i should use to make sure I accurately spray the areas needed. And if I have a different spray size in the future how would i decide on my cell size.
HI Ethan,
As mentioned in the support ticket:
You can set the cell size equal to the implement variable sections, but the reality is that it will never overlay precisely on the field. Still, the error will be small in the intersections between different zones.
Feel free to share more information about your project to guide you better.
In the future, you can always adjust the size of the implement you will use.
