Suggestion about new workstation (I9 CPU)
Hi, I need to update my workstation and the seller suggest me to install the new intell’s CPU I9, Is it a good choice? Is it better XEON CPU? Usually I process 500 images more or less.
Hi Gianluca. The i9 series have performed the best relative to other intel and AMD CPUs. Puget Systems has a good comparison article that I will link to below. Just because the i9 performs better does not mean that you need to use, however. You should consider other things like budget and workflow requirements. 500 images is not very big and a high-end i9 may be overkill.
https://www.pugetsystems.com/all_articles.php?tag=Pix4D
 Within the i9 series, the higher end the model the better the performance. But there are diminishing returns in terms of the marginal value added for the higher end models. The best value is at the mid-tier models but if you want to squeeze as much as you can out of the CPU then the highest end models do perform a bit better.
 I will also include some general articles which you can share related to hardware and processing in Pix4D.
Hardware Components Usage when processing with Pix4D
Processing Speed
System Requirements
Pix4D Computer hardware community benchmark
PC Hardware Articles in Category “Pix4D”
