Show the customer the view I see
I’m fairly new to Pix4D but have really been enjoying it over the past few months. I’ve figured out quite a bit, but I’ve run into a new question.
I map golf courses across the U.S. and usually send my clients a link to view their course. On my computer, I can use the Split View to display the TGI color layer, but when I share the link, my clients don’t see the same detailed view and can’t access the Split option.
Is there a way for me to enable that view or share it so they can experience the same display I see?
Thank you for your help,
Hi, it’s not possible to share the same view form PIX4Dfields. There’s no split view in PIX4Dcloud unless you have a PIX4Dcloud advance license.
But you can adjust the histogram in Pix4Dcloud project, it will be saved and your clients will see it.
Awesome!! Thanks. That was easy to click. I will send it to my people and they will have multiple links so they can see different views.
Thanks!
Thank you so much.
I’m loving the Pix4Dfield so much with my new drone business.
Thank you for your guidance.
We are glad you like PIX4Dfields so far.
All the best in your new business.
