Is there an option to share the cloud processed project with the zoomed scale … here is an example in an Esri Story map … select the bullet 9 and you can see the processed ortho but the viewer would need to zoom in to see detail. Any suggestions? Thank you!!
You could do the same for the shared output using Pix4D cloud. You can scroll your mouse to zoom in and zoom out. To share the project using Pix4D cloud, follow the steps in article 215858503.
