Ruler in 2D
Hello, can we use the ruler just with de 2D mode in Pix4DMatic ?
I just have to measure objects seen from above, length and width…
Thank you very much
Hello Lucas,
I replied to this question in your request #145633 but let me share it with the community as well:
Unfortunately, using the ruler is only available in the 3D mode.
Having said that, measuring using the 3D mode should be perfectly acceptable as long as the project has been processed correctly and there are no major errors.
Anastasis
We aim at porting all (or most!) capabilities of the 3D view to the 2D view eventually, e.g. selecting tie points, picking a point and seeing its related images and of course the measurement functionality. This will be addressed eventually, thanks for sharing and confirming the need for this!
