Dear community,
I’m currently processing NIR and RGB 16-bit GeoTIFFs in Pix4Dmapper version 4.10.0. I’ve successfully processed the same type of images before using the same workflow, but I’m now running into an issue.
In the first step, I process all NIR and RGB images together, and everything looks fine — I can see the colors properly in the rayCloud.
However, in the second step, I choose to process only the RGB images (to reduce memory usage). The resulting orthomosaic file after the third step, however, is named with a _grayscale suffix, and when I open it in QGIS, it contains only a single grayscale band instead of a color composite.
Does anyone know what could be causing this or how to prevent Pix4D from outputting a grayscale orthomosaic in this situation?
Thank you in advance for any insights or suggestions!
Best
JH
