when I reopen already finished project from my folder it asks me to restart the whole project again step 1,2,3.
If I have done and completed all the steps why cant I see the finishing project.?
When reopening a completed project in PIX4Dmapper, it should not require you to restart the entire process if all steps have been successfully completed. Here are a few things to check:
Project Files : Ensure that all necessary project files, including the .p4d file and results folder, are intact and located in the correct directory.
Project Path : Verify that the project path is correctly set and that the software is accessing the right location where the project files are stored.
Processing Status : Double-check that all processing steps 1, 2, and 3 were indeed completed and saved. You can do this by reviewing the Quality Report or checking the status in the software.
