I need to map a 150 acre residential neighborhood using a Phantom 3 Professional. I believe I have two options:
- Create separate projects in Pix4D (of about 250 pictures each) and later find a way to tie them together, or
- Take all the photos (probably more than 5000) and then generate a 3D mesh from all of these? I would not be able to take all the pictures on a single day, which could create problems.
If the answer is 1., how can I tie different projects together? I was thinking of creating a KML of each file and opening all at the same time in Google Earth to visualize the entire neighborhood.
Thank you for your time
