Radiometric correction
Why can’t I turn the radiometric correction on before I process a folder of photos?
If suitable imagery is detected, radiometric correction will be automatically turned on.
Im not sure why my image isnt suitable, im using a a P1 camera on an M400 and using a sentara reflectance panel. I hold the drone above the panel approx one metre then take the photo, and i make sure that im not shadowing the panel. Does the panel need to take up a certain area of the image? ie should i take a closer photo?
The P1 is an RGB camera. No radiometric correction is possible for this.We support radiometric correction only for multi-spectral cameras.
