Thank you for your reply. In pix4d when you do the index calculation it is asking for an albedo value, what can I put for that value?
Thank you.
Zaki.
Thank you.
Zaki.
Hi Zaki, you do not have to put anything there. You do not have to use radiometric correction, just use no correction,
Thank you for your reply. In that case I get a value between 0 and 99999 or similar. If I put an albedo value, then my values come between 0 and 0.99 and that is what I am looking for.
Thank you.
Zaki.
Zaki, That’s weird, if you are using rjpeg images, the temperature value you get should be absolute in degree C. Are you using rjpeg images? can you also send me a screenshot of the index calc showing the values?
