It’s possible to propose the quality report from PIX4Dcloud Advanced in xml ? because what I can see it’s only in pdf.
Thanks in advance
Adrien
Thanks in advance
Adrien
Hello Adrien,
The xml file should be available for all projects processed in the cloud (unless they are uploaded from PIX4Dcatch) together with the PDF.
You have to go to Files&Exports-> Download
If for whatever reason your project does not have that fxml file, please contact support so that we can see what is going on.
Daniel.
Thanks for your answer.
Unfortunately, PIX4Dcatch uses a different process that does not generate the xml file.
Daniel.
