Can I please get some advice on the best workflow step by step when processing a aerial dataset with GCPs on a Custom CRS
Using PIX4dMaticPRO
AGLIME94
Using PIX4dMaticPRO
AGLIME94
Hi Allan,
Processing with an arbitrary coordinate system is generally the same as working with a known coordinate system. The main difference is that PIX4Dmatic cannot automatically locate the images, since their positions relative to the GCPs are unknown. As a result, you will need to manually browse through the dataset to identify the corresponding images, which can be time-consuming and increases the risk of errors.
To help with this, we recently released an online Site Localization Calculator. If you have a table of GCPs defined in both a local and a known/global coordinate system, the calculator can generate a file that automatically geolocates your project. This can significantly speed up project setup and help ensure that GCPs are marked correctly.
You can read more about the site localization calculator in our support article:
