Images (GoPro Hero4Black 3.0 3000x2250 RGB) used for initial processing (Step 1) were taken in wide mode.
I thought a data display issue or a graphics card driver not up to date but it seems that this is not the case
As you will see in the images attached below, the LAS file generated in Step 2 is not good. In XYZ export, it’s the same problem.
The points of densification of the cloud are not random, they are on in lines (spaced in X of 6 cm and spaced in Y of 50 cm).
The images come from GoPro 4 (WIDE mode), we do not use the Pixhawk flight logs, we have failed with GCP points from a geometer survey.
Do you know where this “bug” comes from?
Thank you in advance for your clarification.
STEP 1:
STEP 2:
Densified point cloud in Global Mapper :
