I’m attempting to generate a new point cloud after initial processing using a processing area. Once I hit start the processing area is not visible in the rayCloud window although it is present in the layers. Is this normal?
Hello Brandon,
Did you draw the processing area according to the instructions described here: https://support.pix4d.com/hc/en-us/articles/202560179
What can you see in the rayCloud? The entire area or nothing?
You can focus on the processing area by selecting from the menu bar rayCloud -> Viewpoint -> Focus on Selection
