Processing area export
Is it possible to export the processing area i made to a .shp file, so i can reuse it in the following survey?
I do monthly surveys of the same area to monitor progress, so this would be very handy.
Thanks!
You can’t directly export processing area. You could draw a polyline that you want to use as a processing area export it as .shp then import it as processing area in map view.
Ok, but that requires additional steps. Shame this can’t all be done in Pix4d itself.
All can be done in Pix4Dmapper
You just need to export the polyline once. After that you can use same .shp file as processing area
Just import the processing area that you defined using polylines
