Desktop Pix4Dmapper: cannot import shapefile as a processing area
whenever I want to import a shapefile by following: view > map view > processing area > Import > selecting the file with extension .shp and clicking on “open” I get the following error message and the import is not performed:
“cannot Import valid area from the selected file.” warning w0048.
I have no idea how to solve that problem.
Hi Claudia,
Pix4D Desktop failed to import your shapefile because it is a polyline and not a polygon.
For future projects, please ensure that your shapefile is defined as a polygon and not as a polyline. If your SHP is a polyline, convert it to a polygon with a compatible third-party software, and then import it into Pix4D Desktop.
Hope this will help,
Hi Marco,
thanks for your reply.
I thought that the files provided for the exam where ready to use without any further conversion.
I am referring to the processing area files provided for exam action item four.
I thought the reason for my problem might be that the file name mentioned in the instructions pdf differs from the name of the files being provided for the download, I mean the file name before the extension .shp.
Would be great if you could check the files being provided for the exam download.
Thanks Claudia
Hi Claudia,
I did not understand that you were referring to a shapefile provided by one of our training programs. Under normal circumstance, the files provided for the exam are ready to use without any further conversion
I will report this to our Training Team.
Thank you for your feedback. Your comments are precious.
Hi Claudia,
You will receive a direct message shortly regarding the error message that you received.
Andrew
Any update on this? I get the same warning when importing a .shp polygon. Thanks!
Would you please clarify if you have a problem importing the files that are provided for the exam?
