Poor image results
I am trying to make a 3d rendering of a house with poor results. I have taken over 250 geo referenced images from every possible angle and overlap. Once complete the results are not complete with many missing parts of the house. Any ideas what would cause this or how can I fix it
Are you using the aerial oblique processing mode?
Have you considered making manual tie points?
Hi Buckley,
I suppose that some images did not get calibrated. Images that have low overlap will not get calibrated. For example, if you take images of a wall of your building and at the end of the wall you make a big jump (turn) to take images of the next (perpendicular) wall, you might have a gap (lack of overlap) between these images.
If this is the case, I would recommend you to split your project in sub-projects of good overlap, process them individually and then merge them with manual tie points.
Hope it helps,
Marc
