Pix4DFields Data Folder
After two years of use, and many crashes, a folder on my processing drive called “pix4dfields/data” is full of very large .tiff files. Some are from 2024. I don’t know if these are temporary files or needed for operation. I have ignored them for a long while thinking that they are necessary. But I am now looking for ways to free space.
May I delete these?
-Mike
In PIX4Dfields, the Data storage folder is described as where the actual project files are stored, not just temporary cache.
What this means:
  • Do not mass-delete the folder blindly if you may still need those projects in PIX4Dfields.
  • If you delete files from the data storage folder, projects may no longer be available/imported properly in PIX4Dfields.
  • PIX4D recommends exporting projects for backup before deleting them.
Best practice:
  1. Open PIX4Dfields.
  2. Check Settings > Data storage folder to confirm that this is the active storage location.
  3. Identify which old projects you no longer need.
  4. Export or back up any project you may want to keep.
  5. Delete them from the PIX4Dfields UI by using the bin icon. This will erase the files in data folder.
