Hi all,
I’ve just created a project using a DJI Mavic 3 Multispectral linked to an RTK base-station. I can successfully import the .TIFF files and generate indexes etc in Fields, but how/where do the accurate RTK information get imported? My understanding (could be wrong!) is that the RTK data is stored in the .MRK file that is also created by the drone, and stored in the same folder as the image files.
I cannot validate if the RTK data generated in the flights is actually being used by Fields.
I also found that swapping batteries mid-mission generates multiple folders, and so splits the images, which means I can only import part part of the project into Fields rather than all!
