Pix4D Capture Pro Mission Split
When using the mission split feature on Pix4D Capture Pro, what overlap is there between each mission?
Hello @uasteam ,
Thank you for your question.
1. Each sub-mission after the split process will inherently maintain the same front and side overlap settings that were defined for the original, larger mission. So, the image capture within each individual sub-mission is planned with those specified overlap values.
2. Inter-Mission Overlap (at Borders): When these sub-missions are created adjacent to each other, our well-designed splitting algorithm should also ensure sufficient overlap between the flight lines at the borders of these neighboring sub-missions. This was studied carefully to ensure that the data from all sub-missions could be seamlessly processed and stitched together without gaps or weak areas along the whole project area.
Let me know if this helps.
Daniele
Thanks for the reply, I’ll be flying some missions next week using the split feature.
