Does the Parrot Anafi USA have a Global Shutter or Linear Rolling Shutter?
I am unsure what to select in Pix4D mapper or if the default camera settings are correct. The default setting for this camera is Global Shutter. Thank you,
Hello, You can select the default setting on the camera unless you see a big linear rolling shutter effect on your raw images.
Just for information, your Parrot Anafi USA has a linear rolling shutter and does not have a global or mechanical shutter.
For Pix4D the Global Shutter option option works most of the time. As stated by Pix4D you can always look for motion blur in your images and if noted, change thius setting to correct for it.
