point cloud has been output as a .p4d file instead of a .las file when i processed in rapid mode. I need it in .las or similar to load into i-site
Hi Tim,
the 3D Maps - Radip/Low Res and_ 3D Models - Rapid/Low Res_ templates do not generate the _.las _file by default. To generate it, please ensure that in the Processing Options of Step 2. Point Cloud and Mesh, the LAS box is checked as Export format.
